  Visitors: 3428
CAD tip CAD tip # 14147:
Select map features OUTSIDE the selected polygon in Map 3D.
A - answer If you need to select only the objects outside the marked polygon from the connected data source in AutoCAD Map 3D or Civil 3D in the "View Manager" (Tools > Search and select elements), add the logical operator NOT ("without") before the standard function "Find on map > Inside > Polygon" - see the picture:
MapCivil3D
17.6.2024    1106×
Prices - CAD eShop:
applies to: AutoCAD Map 3D · Civil 3D 3D ·
Tip 13706:Visual style Sketchy with colored edges.
Tip 13505:How to find which version of Inventor has saved a file?
Tip 12136:Security settings for Inventor data files and add-on applications.
Tip 8529:How to use CUDA GPU to accelerate rendering in 3ds Max?
Tip 8151:Keyboard shortcuts in AutoCAD for Mac.
