  Visitors: 5467
CAD tip CAD tip # 7435:
Selecting 3D subobjects and hidden objects in AutoCAD 2011.
A - answer AutoCAD 2011 (and higher) offers enhanced options for selecting subobjects in complex 3D scenes. A new system variable CULLINGOBJ controls the highlighting and selection of 3D objects (and faces or edges) which are hidden (invisible) in the current view:
Grip selection, CULLINGOBJ=0 Grip selection, CULLINGOBJ=1
The first image shows the default behavior in AutoCAD 2010 (or when CULLINGOBJ is switched to 0), the second image shows the default behavior in AutoCAD 2011. You can see similar object culling also for rollover highlighting.
The CULLINGOBJSELECTION variable similarly controls the selection of objects which are hidded from view in the current scene. By setting it to 1, the window-selection will filter out objects which are "not visible" (are obscured by another object). This setting can be risky in some situations.
ACAD2012ACAD2011ACAD2010LTADTCivilACADM
30.6.2010    9564×
Tip 12526:BufZone - buffer zones and wipeouts around AutoCAD line objects.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 12040:PaintSelect - select objects by cursor painting - paint selection.
Tip 12034:SolSimilar - select geometrically similar 3D solids.
Tip 11967:How to apply a changed drawing template (DWT) to existing drawings?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
