  Visitors: 7271
CAD tip CAD tip # 10884:
Simple detection of a 2D/3D DWG or an empty DWG.
A - answer If you to find in your utility or menu-macro whether the current drawing is a 2D or 3D drawing file, or whether it doesn't contain any visual entities, you can use the following simple AutoLISP functions (predicates):
;is current drawing 2D? (defun is2D-p () (and (zerop (caddr (getvar "EXTMIN")))(zerop (caddr (getvar "EXTMAX")))) ; Z-boundingbox = 0? ) ;is current drawing 3D? (defun is3D-p () (< (caddr (getvar "EXTMIN"))(caddr (getvar "EXTMAX"))) ; Z-boundingbox ? ) ;is current drawing visually empty? (vl-load-com) (defun isEmpty-p () (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1) (> (caddr (getvar "EXTMIN"))(caddr (getvar "EXTMAX"))) ; min>max? )
The functions - e.g. (is2D-p) - return the values of T (true) or nil (false) in AutoCAD.
ACAD
4.5.2016    4730×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13847:Pringles in AutoCAD - a hyperbolic paraboloid.
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13716:HYPERLIST - list of all used URLs.
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
