CAD tip # 6955:
applies to: AutoCAD · |
Tip 13967: | Drawing polylines using arbitrary length units - 2DpolyC. |
Tip 13887: | ClosestPt - the nearest point on another curve |
Tip 13827: | Snap points to the nearest curve/polyline with Snap2Curve. |
Tip 13653: | FPoly - draw fixed-length polylines in AutoCAD. |
How to set weld symbol size in AutoCAD Mechanical? « | » Can I legally use a second copy of AutoCAD on my other PC?
