  Visitors: 3389
CAD tip CAD tip # 11959:
Supported file types (applications) with reference detection in Autodesk Desktop Connector.
A - answer Autodesk Desktop Connector (version 6.2 for Windows) supports cloud synchronization of the Fusion 360 and BIM 360 virtual disc drives for all file types. However, for the following file types and CAD applications, it also performs automatic detection and processing of any external references (dependencies) found inside these files:
  • Autodesk 3ds Max (64-bit) 2014 and higher
    • .max
  • Autodesk Alias ​​(64-bit)
    • .wire
  • Autodesk AutoCAD (64-bit) 2016 and higher (incl. Civil 3D)
    • .dwg
    • .dwt
  • Autodesk FeatureCAM (64-bit)
    • .fm
  • Autodesk Inventor (64-bit) 2016 and higher.
    • .dwg
    • .iam
    • .idw
    • .ipn
    • .ipt
  • Autodesk OMV (On Machine Verification, Power Inspect, 64-bit)
    • .mpf
    • .msr
    • .dat
    • .log
    • .a
  • Autodesk PowerInspect (64-bit) 2018.1 and higher
    • .pwi
  • Autodesk PowerMill (64-bit)
    • .pmlprj
  • Solidworks (64-bit) 2015 and higher
    • .asm
    • .drw
    • .prt
    • .sldasm
    • .slddrw
    • .sldprt
Download the current version of Desktop Connector at Download
ACADInvBIM360AliasMax
100% *  CAD,CAM
29.7.2018    3099×
applies to: AutoCAD · Inventor · BIM360 · Alias · 3ds Max ·
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12667:How to free up space in the local cache of Desktop Connector?
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
