  Visitors: 6253
CAD tip CAD tip # 6689:
Switching Display configurations from command line.
A - answer If you need to switch Display configurations in your AutoCADu Architecture session from a macro, script or directly from the command line, you can use the line command -AecDisplayConfigSetCurrent instead of the interactive select box.
You need to supply the name of an existing Display configuration in this command.
ADT2010ADT2009ADT2008
21.5.2009    5424×
Prices - CAD eShop:
Tip 12103:Random lines are displayed over my AutoCAD drawing.
Tip 11523:How to reset default dialog positions and sizes in Fusion 360?
Tip 11374:How to disable the Welcome screen in Fabrication CAMduct?
Tip 10828:How to control download and installation of updates in Autodesk Desktop App?
Tip 10188:Setting display quality in InfraWorks 360.
