  Visitors: 7457
CAD tip CAD tip # 12117:
The Ctrl+Shift+letter hotkeys do not work (e.g. Ctrl+Shift+C in AutoCAD)
A - answer On my computer, AutoCAD, Inventor and other applications stopped to recognize the keyboard shortcuts Ctrl+Shift+C, Ctrl+Shift+S, Ctrl+Shift+L, Ctrl+Shift+M, Ctrl+Shift+R, Ctrl+Shift+G, Ctrl+Shift+E, and other.
This is most probably caused by collision with the function AMD ReLive, a part of the AMD Radeon graphics card driver - see ReLive > Global:
Disable or uninstall this function, or remap its hotkeys. For some applications, ReLive may collide also on other key combinations based on pressing Shift+Ctrl simultaneously.
The hotkey Ctrl+Shift+L is hidden in a different section in ReLive: Gaming > Global Settings > Performance Monitoring > Toggle Performance Logging Hotkey. You can unmap the hotkey by going to its settings (Toggle) and pressing Del.
ACADInvFusion360Max
100% Win10,Win8  CAD
20.1.2019    14380×
applies to: AutoCAD · Inventor · Fusion 360 360 · 3ds Max ·
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
Tip 7953:Toggle model/paperspace with a keyboard shortcut.
Tip 7620:Keyboard shortcut for Select Previous.
Tip 6982:Switching layers using keyboard shortcuts, browsing layers.
Tip 6095:Group selection is not working.
