  Visitors: 10321
CAD tip CAD tip # 9202:
The geolocation LiveMap in AutoCAD 2014 is off scale.
A - answer You are experiencing an offset or wrong scale of the imagery brought into your DWG drawing with the AutoCAD geolocation function (LiveMap). A building footprint appears smaller or larger than the live map data.
Make sure you have choosen the right "Drawing units" and "GIS Coordinate System" in the Geographic Location dialog. Your DWG objects may use other units/scale or another CS.
ACAD2014LT2014ADT2014Civil2014Plant2014
16.4.2013    13016×
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 12881:How to attach multiple raster images to my DWG in one go?
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 10848:GeoCode with what3words location codes.
Tip 9860:Displaying a DWG including GPS position on a mobile phone or tablet.
