  Visitors: 4768
CAD tip CAD tip # 8436:
The RegistryVersion codes for individual versions of Inventor.
A - answer CAD application Autodesk Inventor uses a product code (RegistryVersion) to store its settings in the Registry -- this code distinguishes the individual Inventor versions. Unlike AutoCAD, this key name does not carry the language version (this is stored in the key Language) nor the variety/edition of Inventor (see the key ProductEdition).
This versioning is used in the Registry hives:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor
and
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Inventor
The individual Inventor versions use the following RegistryVersion codes:
  • 2012 - RegistryVersion16.0
  • 2011 - RegistryVersion15.0
  • 2010 - RegistryVersion14.0
  • 2009 - RegistryVersion13.0
  • 2008 - RegistryVersion12.0
  • R11 - RegistryVersion11.0
  • R10 - RegistryVersion10.0
  • R9 - RegistryVersion9.0
  • R8 - RegistryVersion8.0 (RegistryVersion8.9 for DX)
  • R7 - RegistryVersion7.0
  • R6 - RegistryVersion6.0
  • R5.3 - RegistryVersion5.2
  • R5 - RegistryVersion5.1
Inventor
25.1.2012    7806×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13819:Position and docking of the Measure palette in Inventor 2024.
Tip 12152:Sketch lines linewidth - how to make Inventor lines thicker for a 4K display?
Tip 10596:Changing colors of the Inventor color schemes (UI).
Tip 9937:Preset displaying of thread features in Inventor 2015 drawing views.
Tip 8314:How to switch Inventor from ribbon to classic UI?
