  Visitors: 8715
CAD tip CAD tip # 8882:
The Ribbon does not have any tabs or panels currently loaded.
A - answer AutoCAD displays no ribbon (an empty top menu) and reports the error "The Ribbon does not have any tabs or panels currently loaded".
It is usually caused by a missing or damaged menu definition file - CUI or CUIx (e.g. ACAD.cuix or C3D.cuix) or an improperly set workspace.
A missing CUI file can be loaded with the CUILOAD command. A damaged CUIx file can be restored using the CUI command - right-click on the customization file name (top left) - e.g. "ACAD" - and from its context menu choose "Reset":
Reset CUI (CZ version)
Confirm the dialog with OK.
To select a proper workspace use the gear icon in the bottom bar or enter the WORKSPACE command and choose Setting.
ACADLTADTCivilMap
25.10.2012    39904×
Tip 13620:How to quickly rotate the view by 90° in AutoCAD LT?
Tip 13529:How to redefine the behavior of a standard AutoCAD command?
Tip 13274:How to switch the DWG TrueView viewer to the classic user interface, without ribbon?
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 11650:How to add AutoCAD toolbars to AutoCAD Mechanical menus?
LogOff 2006 More info
