  Visitors: 5175
CAD tip CAD tip # 8727:
Transparent 3D views in Revit.
A - answer In some situations, Revit 2013 may improperly display and print (raster output, PDF, paper) shaded/rendered 3D views - windows and other transparent or glass elements are displayed even on hidden parts of the building. So the solid walls appears to be semi-transparent, see-through, glass-like:
Windows showing through
The source of this problem is an incompatibility of your graphics card, or its driver. Try to update your gr.card Windows driver, make sure you are using an Autodesk-certified graphics card (accelerator). If your card is not compatible, disable its hardware acceleration in Revit (Options > Graphics).
You can also try to enable the "Photographic Exposure" mode in Realistic views (see "Graphic display options" in the 3D view properties):
Exposure (CZ version)
Revit2013
31.7.2012    19326×
Prices - CAD eShop:
applies to: Revit 2013 ·
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 13103:How to embed an interactive Revit 3D model into a Powerpoint presentation?
Tip 11909:Using luminiscent materials in AutoCAD 3D scenes.
Tip 11425:Contour lines on a toposurface are displayed as too thick lines.
