  Visitors: 4690
CAD tip CAD tip # 10820:
Unable to save to drawing c:\folder\filename.dxf
A - answer AutoCAD refuses to export the drawing to an older-version DXF file format using the commands DXFOUT or SAVEAS - reports the error Unable to save to drawing c:\folder\filename.dxf.
The drawing is probably corrupted or contains invalid objects. Perform AUDIT and fix any errors. Then retry DXFOUT.
ACAD
30.3.2016    7356×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 6737:3ds Max reports the error eNotImplementedYet on DWG import.
Tip 5804:Xref message: Unable to detach. Multiple references detected.
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
