  Visitors: 5389
CAD tip CAD tip # 9674:
Vault: Check-in drawings along with the models.
A - answer If you want to check-in (save) your drawings together with checked-in models of an Inventor part or assembly, use the respective button for related files in the middle of the Vault Check-in dialog. You can setup what type of files should be searched (presentations, IDW/DWG drawings) and where they should be searched.
Included file types:
The resulting check-in of models and drawings:
VaultInventor
28.1.2014    6292×
Prices - CAD eShop:
applies to: Vault · Inventor ·
Tip 13599:How to read iProperties from Inventor models and drawings in AutoCAD DWGs?
