CAD tip # 11801:
applies to: Inventor · |
Tip 13211: | Automatic numbering/renaming of multi-volume bodies in a part. |
Tip 13040: | iLogic - display information about complexity of an Inventor part. |
Tip 12828: | How to quickly delete 3rd party links to external objects in Inventor? |
Tip 12712: | How to set the option "Active Window on Save" through iLogic? |
Tip 12697: | Opposite angle for angular dimensions in Inventor drawings (iLogic). |
Higher precision for facetted round surfaces in STL export from Inventor. « | » Undocumented code in field expression - MText contents without control characters.
