  Visitors: 7772
CAD tip CAD tip # 9910:
What is the maximum number of points in point clouds displayed in AutoCAD?
A - answer The maximum number of displayable points in point clouds imported resp. attached (POINTCLOUDATTACH) into AutoCAD from the capture application Autodesk ReCap (.rcp) is 25 million in AutoCAD 2015 (in AutoCAD 2014/2013 it was 10 million). For 32-bit versions of AutoCAD (and for AutoCAD 2012/2011), this maximum is at 1.5 million points. Point clouds in old legacy file formats have a maximum of 10 million points.
This limitation applies as a total of all points clouds attached in the respective drawing. The setting is stored in the POINTCLOUDPOINTMAX variable (POINTCLOUDPOINTMAXLEGACY for legacy formats)).
For setting go to Options > 3D Modeling:
ACAD2015ACAD2014ADTCivilMapPlant
17.7.2014    12233×
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Tip 12938:How to convert a point cloud to a textured 3D model?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12296:Loading a point cloud from a series of photos to Revit.
LogOff 2006 More info
