  Visitors: 6574
CAD tip CAD tip # 9927:
What is the maximum size of a polyface mesh in AutoCAD?
A - answer AutoCAD can create and process polyface mesh surfaces (PFACEMESH, AcDbPolyFaceMesh, the command PFACE) up to the size of 32767 vertices.
The newer mesh-type object (sub-division MESH, AcDbSubDMesh, the command MESH) can contain up to 16.7 million faces.
ACAD
1.8.2014    8253×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14095:How to increase the accuracy (smoothness) of STL files exported from AutoCAD?
Tip 14072:How to import an STL, OBJ or 3DS file to an AutoCAD 3D model?
Tip 13559:How to find the number of faces of a 3D mesh object in Fusion 360?
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
