CAD tip # 7565:
Tip 11469: | Why you should not use the DEFPOINTS layer to draw geometry? |
Tip 10820: | Unable to save to drawing c:\folder\filename.dxf |
Tip 10612: | Revit error: Unable to open because of unresolved pointer references |
Tip 9276: | AutoCAD reports some xrefs as "Unresolved". |
Tip 9081: | Error: Bad DXF group: (10) |
Undocumented AutoCAD system variables.
3D print (export) in the STL format is 10x smaller than the 3D model. « | » Find all DWG drawings with the given text in a block attribute.
