  Visitors: 4765
CAD tip CAD tip # 9220:
Why does Inventor load my assembly in Express Mode?
A - answer By default, Inventor 2014 loads IAM assemblies in standard (full) mode and uses the Express mode only on demand (see Assemble > Productivity, or the checkbox in Open > Options...). But if an assembly contains more than 500 parts (referenced files) and the Express mode is available, this assembly is opened directly in the Express mode. This behaviour and the number of files can be set in the Application options on the Assembly tab:
Assembly options in Inventor 2014 (CZ)
If you have your IAM assembly opened in the fast Express mode (will be indicated as shown below) and you need one of those editing functions which require the full mode, you can use the button "Load Full" (available in all ribbon tabs).
Load Full (CZ)
Inventor2014
23.4.2013    9227×
Prices - CAD eShop:
applies to: Inventor 2014 ·
Tip 14098:How to use arc length parameter in Inventor sketch?
Tip 14027:3D heart from the heart.
Tip 13906:How to construct a 2D spiral shape in Inventor?
Tip 13611:BOM with multi-line items in Inventor.
Tip 12638:How to use conditional parameter values in Fusion 360?
LogOff 2006 More info
