  Visitors: 4458
CAD tip CAD tip # 7857:
Why the MESHSPIN command complains about the object type?
A - answer The function "Spin Triangle Face" (MESHSPIN) works only with 3D objects of the type Mesh, composed from triangular faces. In these neighbouring faces you can swap their common edge.
On a meshed regular object composed from quad faces you can use the command MESHSPLIT with the Vertex option to create triangular faces.
Original mesh
Original mesh
Split face
Split face
Selection for spin
Selection for spin
Swapped face
Swapped face of the mesh
The MeshSpin function is intended mainly for irregular objects, to solve boundary shapes.
ACAD2011
14.3.2011    4747×
Prices - CAD eShop:
applies to: AutoCAD 2011 ·
Tip 12938:How to convert a point cloud to a textured 3D model?
Tip 12749:Generate parametric mathematical 3D surfaces (meshes) in Fusion 360.
Tip 12710:Boolean subtraction of 3D mesh objects in Meshmixer.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 12233:How to compare two 3D mesh models and find differences/changes?
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
