  Visitors: 9303
CAD tip CAD tip # 13437:
Zoom on predefined annotation scales.
A - answer Using the ANNOSCALEZOOM variable introduced in AutoCAD 2023, you can zoom viewports using the mouse wheel in predefined steps, following each defined annotation scale.
While the standard zoom changes the view in smooth, subtle steps, when ANNOSCALEZOOM is enabled, the zoom behavior will change and the view scale will switch from one fixed scale to the next higher or lower scale. If you have set the drawing to display annotations depending on the selected scale, the drawing will also switch in pre-known increments and display states.
See sample:
(and a video)
ACAD2023ACLT2023ADT2023ACADM2023Plant2023Civil2023
18.8.2022    2536×
Tip 13286:Markup assistant with intelligent character recognition.
Tip 11830:How to influence linetype scale or color for hidden edges in documentation views?
Tip 11757:How to change blocks properties ex-post: annotative, allow exploding, scale uniformly
Tip 11729:Select objects by annotation scale.
Tip 9153:Arrowheads or other parts of dimensions are not printed.
