  <title>CAD F&#243;rum : Import *.skp</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Import *.skp]]></description>
  <pubDate>Wed, 23 Sep 2026 15:48:59 +0000</pubDate>
  <lastBuildDate>Tue, 05 Jan 2010 08:46:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=10087</WebWizForums:feedURL>
   <title><![CDATA[Import *.skp : Do STEPu ne, ale do DWG, DXF,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49926&amp;title=import-skp#49926</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10087<br /><strong>Zasláno:</strong> 05.led.2010 v 08:46<br /><br />Do STEPu ne, ale do DWG, DXF, DGN nebo ACIS (SAT).]]>
   <pubDate>Tue, 05 Jan 2010 08:46:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49926&amp;title=import-skp#49926</guid>
   <title><![CDATA[Import *.skp : A je mo&#382;n&#233; z Revitu exportovat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49925&amp;title=import-skp#49925</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=16">ssmiga</a><br /><strong>Předmět:</strong> 10087<br /><strong>Zasláno:</strong> 05.led.2010 v 08:38<br /><br />A je možné z Revitu exportovat např. do stepu apod.?]]>
   <pubDate>Tue, 05 Jan 2010 08:38:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49925&amp;title=import-skp#49925</guid>
   <title><![CDATA[Import *.skp : Z Autodesk produkt&#367; na&#269;&#237;t&#225; SKP...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49923&amp;title=import-skp#49923</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10087<br /><strong>Zasláno:</strong> 05.led.2010 v 08:29<br /><br />Z Autodesk produktů načítá SKP formát přímo jen Revit. Ze SketchUp ale můžete exportovat např. DXF.]]>
   <pubDate>Tue, 05 Jan 2010 08:29:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49923&amp;title=import-skp#49923</guid>
   <title><![CDATA[Import *.skp : Zdrav&#237;m v&#353;echny invertor&#225;&#345;e v...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49922&amp;title=import-skp#49922</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=16">ssmiga</a><br /><strong>Předmět:</strong> 10087<br /><strong>Zasláno:</strong> 05.led.2010 v 08:22<br /><br />Zdravím všechny invertoráře v novém roce,<DIV>&nbsp;</DIV><DIV>nezkoušel jste někdo dostat do inventoru model ve formátu *.skp? </DIV>]]>
   <pubDate>Tue, 05 Jan 2010 08:22:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10087&amp;PID=49922&amp;title=import-skp#49922</guid>
