  <title>CAD F&#243;rum : Pls help :)</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Pls help :)]]></description>
  <pubDate>Sun, 09 Aug 2026 21:03:21 +0000</pubDate>
  <lastBuildDate>Fri, 15 Jan 2010 18:20:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=10183</WebWizForums:feedURL>
   <title><![CDATA[Pls help :) : d&#237;k moc :) uplna parada :)  ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50343&amp;title=pls-help#50343</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21977">stalin</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 18:20<br /><br />dík moc :) uplna parada :)]]>
   <pubDate>Fri, 15 Jan 2010 18:20:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50343&amp;title=pls-help#50343</guid>
   <title><![CDATA[Pls help :) : OK - tady jsou p&#345;eveden&#233; DWG: ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50342&amp;title=pls-help#50342</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 18:16<br /><br />OK - tady jsou převedené DWG:<DIV><a href="http://www.cadforum.cz/forum/uploads/20100115_181517_podpera-dwg.zip" target="_blank">uploads/20100115_181517_podpera-dwg.zip</A></DIV>]]>
   <pubDate>Fri, 15 Jan 2010 18:16:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50342&amp;title=pls-help#50342</guid>
   <title><![CDATA[Pls help :) : potrebuji jen vykresovou dokumentaci...model...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50341&amp;title=pls-help#50341</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21977">stalin</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 18:04<br /><br />potrebuji jen vykresovou dokumentaci...model nepotrebuji vubec..]]>
   <pubDate>Fri, 15 Jan 2010 18:04:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50341&amp;title=pls-help#50341</guid>
   <title><![CDATA[Pls help :) : P&#345;evod v&#253;kresov&#233;ho listu bez modelu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50339&amp;title=pls-help#50339</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 18:02<br /><br />Převod výkresového listu bez modelu asi nemá příliš smysl - nebo jde jen o to získat statickou malůvku?]]>
   <pubDate>Fri, 15 Jan 2010 18:02:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50339&amp;title=pls-help#50339</guid>
   <title><![CDATA[Pls help :) : uploudnul jsem to zde...http:/...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50337&amp;title=pls-help#50337</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21977">stalin</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 17:54<br /><br /><P>uploudnul jsem to zde...http://ulozto.cz/3657764/podpera.rar</P><P>potreboval bych jen prevest ty *.idw na starsi verzi(inv nebo cad 09) nebo nejlepe do *.dwg </P><P>Moc dekuji za ochotu a pomoc :)</P>]]>
   <pubDate>Fri, 15 Jan 2010 17:54:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50337&amp;title=pls-help#50337</guid>
   <title><![CDATA[Pls help :) : P&#345;eulo&#382;it do star&#353;&#237;ch verz&#237; to...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50336&amp;title=pls-help#50336</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 17:49<br /><br />Přeuložit do starších verzí to nejde. Mohu vám to vyexportovat třeba do STEPu (tělesa bez vazeb a parametrů). Uložit to můžete třeba na iProject.cz]]>
   <pubDate>Fri, 15 Jan 2010 17:49:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50336&amp;title=pls-help#50336</guid>
   <title><![CDATA[Pls help :) : a nemohl by jste mi to pls preulozit? ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50335&amp;title=pls-help#50335</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21977">stalin</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 17:22<br /><br />a nemohl by jste mi to pls preulozit?]]>
   <pubDate>Fri, 15 Jan 2010 17:22:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50335&amp;title=pls-help#50335</guid>
   <title><![CDATA[Pls help :) : Ukl&#225;dat do star&#353;&#237;ch verz&#237; nejde,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50334&amp;title=pls-help#50334</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 17:18<br /><br />Ukládat do starších verzí nejde, jedině přes výměnné formáty - viz:<DIV><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=4258" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=4258</A></DIV>]]>
   <pubDate>Fri, 15 Jan 2010 17:18:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50334&amp;title=pls-help#50334</guid>
   <title><![CDATA[Pls help :) : lidicky mam problem mam jen inv...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50331&amp;title=pls-help#50331</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=21977">stalin</a><br /><strong>Předmět:</strong> 10183<br /><strong>Zasláno:</strong> 15.led.2010 v 16:44<br /><br />lidicky mam problem mam jen inv 09 a vykresy mam v inventoru 2010 nemohl by jste mi pls poradit jestli nejde stahnou jen nejaka jednouducha nastavba?abych to mohl otevrit...nebo nemohli by jste mi to nekdo preulozit?]]>
   <pubDate>Fri, 15 Jan 2010 16:44:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10183&amp;PID=50331&amp;title=pls-help#50331</guid>
