  <title>CAD F&#243;rum : problemy s prevodom na editable poly</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : 3ds Max, Maya, VRED : problemy s prevodom na editable poly]]></description>
  <pubDate>Mon, 05 Oct 2026 09:58:30 +0000</pubDate>
  <lastBuildDate>Fri, 29 Jan 2010 19:54:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=10240</WebWizForums:feedURL>
   <title><![CDATA[problemy s prevodom na editable poly : nevim co si predstavit pod pojmem...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10240&amp;PID=50921&amp;title=problemy-s-prevodom-na-editable-poly#50921</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=2514">Biolit</a><br /><strong>Předmět:</strong> 10240<br /><strong>Zasláno:</strong> 29.led.2010 v 19:54<br /><br />nevim co si predstavit pod pojmem rozsypat, ale pokud chcete prevezt krivky v MAXu, musite je prevezt na "editable spline", ne "editable poly" ]]>
   <pubDate>Fri, 29 Jan 2010 19:54:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10240&amp;PID=50921&amp;title=problemy-s-prevodom-na-editable-poly#50921</guid>
   <title><![CDATA[problemy s prevodom na editable poly : problem s pou&#382;it&#237;m editable poly...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10240&amp;PID=50745&amp;title=problemy-s-prevodom-na-editable-poly#50745</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=22191">cicmo</a><br /><strong>Předmět:</strong> 10240<br /><strong>Zasláno:</strong> 25.led.2010 v 11:34<br /><br /><SPAN =msgtitle><strong>problem s použitím editable poly </strong></SPAN><DIV =msgtext>Caute, poradte mi pls niekto.<BR>Pri importovani dwg suboru som mala vsetky usecky v cade prevedene na polyline. Vsetko sa mi v pohode importovalo a ked som dala objekt previest na editable poly cele sa mi to rosypalo <img src="http://www.grafikapro.sk/components/com_fireboard/template/default_gray/images/english/emoticons/sad.png" border="0" style="BORDER-RIGHT-WIDTH:%200px;%20BORDER-TOP-WIDTH:%200px;%20BORDER-BOTTOM-WIDTH:%200px;%20VERTICAL-ALIGN:%20middle;%20BORDER-LEFT-WIDTH:%200px" /><BR>Neskor som prisla na to, ze aj line vytvorena v maxe a prevedena na editable poly sa mi po prevode strati. Ona tam je, len ja ju nevidim.</DIV>]]>
   <pubDate>Mon, 25 Jan 2010 11:34:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10240&amp;PID=50745&amp;title=problemy-s-prevodom-na-editable-poly#50745</guid>
