  <title>CAD F&#243;rum : CTB / STB - nastavenie</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : CTB / STB - nastavenie]]></description>
  <pubDate>Tue, 03 Nov 2026 02:44:58 +0000</pubDate>
  <lastBuildDate>Tue, 02 Feb 2010 10:34:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=10285</WebWizForums:feedURL>
   <title><![CDATA[CTB / STB - nastavenie : Super. Funguje to. Vdaka ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50972&amp;title=ctb-stb-nastavenie#50972</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=8806">jojora</a><br /><strong>Předmět:</strong> 10285<br /><strong>Zasláno:</strong> 02.úno.2010 v 10:34<br /><br />Super. Funguje to. Vdaka]]>
   <pubDate>Tue, 02 Feb 2010 10:34:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50972&amp;title=ctb-stb-nastavenie#50972</guid>
   <title><![CDATA[CTB / STB - nastavenie : convertpstyles ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50971&amp;title=ctb-stb-nastavenie#50971</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 10285<br /><strong>Zasláno:</strong> 02.úno.2010 v 10:27<br /><br />convertpstyles]]>
   <pubDate>Tue, 02 Feb 2010 10:27:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50971&amp;title=ctb-stb-nastavenie#50971</guid>
   <title><![CDATA[CTB / STB - nastavenie : V&#253;kres je nasatven pro pou&#382;&#237;v&#225;n&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50970&amp;title=ctb-stb-nastavenie#50970</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 10285<br /><strong>Zasláno:</strong> 02.úno.2010 v 10:25<br /><br />Výkres je nasatven pro používání stb. Nejdříve ho musíte převést na ctb - příkazem Convert... (přesnou syntaxi teď nevím, když si ji sám najdete, budete si ji lépe pamatovat).]]>
   <pubDate>Tue, 02 Feb 2010 10:25:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50970&amp;title=ctb-stb-nastavenie#50970</guid>
   <title><![CDATA[CTB / STB - nastavenie : dobry den, mam taky problem. Ked...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50969&amp;title=ctb-stb-nastavenie#50969</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=8806">jojora</a><br /><strong>Předmět:</strong> 10285<br /><strong>Zasláno:</strong> 02.úno.2010 v 10:15<br /><br /><P>dobry den, mam taky problem. Ked otvorim vykres, pri tlaci mi dava moznosti vybrat len zpomedzi *.STB stylov pre vykreslovanie. V adresaroch subory stb su nahrate, v options je nastavene v "plot style table settings" polozka "use color dependet plot styles". Ale pri tlaci stale ponuka moznosti vyberu medzi *.stb suborami. neviete kde robim chybu? Dakujem, jojora</P>]]>
   <pubDate>Tue, 02 Feb 2010 10:15:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10285&amp;PID=50969&amp;title=ctb-stb-nastavenie#50969</guid>
