  <title>CAD F&#243;rum : Ovladač HP DesingJet 500</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD hardware : Ovladač HP DesingJet 500]]></description>
  <pubDate>Sat, 05 Sep 2026 10:48:37 +0000</pubDate>
  <lastBuildDate>Wed, 10 Mar 2010 20:02:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=10517</WebWizForums:feedURL>
   <title><![CDATA[Ovladač HP DesingJet 500 : Tak na ten 450c funguje ovlada&#269;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52098&amp;title=ovladac-hp-desingjet-500#52098</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=18">Zouhar</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 10.bře.2010 v 20:02<br /><br />Tak na ten 450c funguje ovladač z 430 i když jen monochrome ale aspoň něco.]]>
   <pubDate>Wed, 10 Mar 2010 20:02:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52098&amp;title=ovladac-hp-desingjet-500#52098</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Ja m&#225;m HP DJ500 PS 42&amp;#034;. Sk&#250;&#353;al...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52069&amp;title=ovladac-hp-desingjet-500#52069</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=70">Ľubomír Pápay</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 22:17<br /><br />Ja mám HP DJ500 PS 42". Skúšal nikto rozchodit tento model?]]>
   <pubDate>Tue, 09 Mar 2010 22:17:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52069&amp;title=ovladac-hp-desingjet-500#52069</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Zdrav&#237;m schodou okolnost&#237; &#345;e&#353;&#237;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52059&amp;title=ovladac-hp-desingjet-500#52059</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=18">Zouhar</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 15:50<br /><br />Zdravím schodou okolností řeším stejný problém dnes s HP 450c, zajímavé je že před týdnem fungoval bez problému na Win7 32 bit na ovladačích Xp. A dnes se ho pokouším celý den rozjed na Win7 64bit a bez úspěchu. Prolezl jsem co se dalo a nic. Tak pokud se Vám to povede rozjet tak dejte vědět. Děkuji]]>
   <pubDate>Tue, 09 Mar 2010 15:50:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52059&amp;title=ovladac-hp-desingjet-500#52059</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Tak u&#382; jsem ten HP500rozchodil...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52058&amp;title=ovladac-hp-desingjet-500#52058</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1383">MarekOpava</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 15:37<br /><br /><P>Tak už jsem ten HP500&nbsp;rozchodil ... pod W7&nbsp;funguje (zatím) ovladač pro XP64 Proffesional! Teď ještě sehnat ovladač pro XP64 nebo Vistu (64) pro HP450C</P>]]>
   <pubDate>Tue, 09 Mar 2010 15:37:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52058&amp;title=ovladac-hp-desingjet-500#52058</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Tak d&#283;kuji ... ale moc m&#283; to nepot&#283;&#353;ilo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52056&amp;title=ovladac-hp-desingjet-500#52056</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1383">MarekOpava</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 14:17<br /><br />Tak děkuji ... ale moc mě to nepotěšilo ...]]>
   <pubDate>Tue, 09 Mar 2010 14:17:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52056&amp;title=ovladac-hp-desingjet-500#52056</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Tak&#382;e e&#353;te raz:http://h20000.w...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52055&amp;title=ovladac-hp-desingjet-500#52055</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 14:05<br /><br />Takže ešte raz:<br>http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01938670&amp;dimid=1051958190&amp;dicid=alr_nov09&amp;jumpid=em_alerts/us/nov09/all/xbu/emailsubid/mrm/mcc/loc/rbu_category/alerts<br><br>Tam sa dočítate, že pre Váš ploter je k dispozícii pre Windows 7 64bit len ovládač s HPGL<br>]]>
   <pubDate>Tue, 09 Mar 2010 14:05:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52055&amp;title=ovladac-hp-desingjet-500#52055</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Na webu firmy WinLine jsem u&#382;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52054&amp;title=ovladac-hp-desingjet-500#52054</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1383">MarekOpava</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 14:02<br /><br />Na webu firmy WinLine jsem už byl taky, ovladač od nich funguje (ale jen jako demoverze, kreslí přes výkres logo firmy) ... jenže chtějí za to cca 5 000,- Kč. Takže hledám nějakou levnější varinatu ...]]>
   <pubDate>Tue, 09 Mar 2010 14:02:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52054&amp;title=ovladac-hp-desingjet-500#52054</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : nebo d&#283;l&#225;m n&#283;co &#353;patn&#283; ... ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52053&amp;title=ovladac-hp-desingjet-500#52053</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1383">MarekOpava</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 13:48<br /><br />nebo dělám něco špatně ... &nbsp;<img src="http://www.cadforum.cz/forum/smileys/smiley7.gif" height="17" width="17" border="0" align="absmiddle" alt="Angry" />]]>
   <pubDate>Tue, 09 Mar 2010 13:48:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52053&amp;title=ovladac-hp-desingjet-500#52053</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : Tam jsem se dostal taky, jen&#382;e...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52052&amp;title=ovladac-hp-desingjet-500#52052</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1383">MarekOpava</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 13:47<br /><br />Tam jsem se dostal taky, jenže nabízí mi to při instalaci jen drivery&nbsp;s&nbsp;HPLG ... a my v plotru HPLG kartu nemáme. Takže to nefunguje ...]]>
   <pubDate>Tue, 09 Mar 2010 13:47:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52052&amp;title=ovladac-hp-desingjet-500#52052</guid>
   <title><![CDATA[Ovladač HP DesingJet 500 : www.hp.cz -&amp;gt; podpora a ovlada&#269;e...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52051&amp;title=ovladac-hp-desingjet-500#52051</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33">Mantlík</a><br /><strong>Předmět:</strong> 10517<br /><strong>Zasláno:</strong> 09.bře.2010 v 13:42<br /><br /><P><a href="http://www.hp.cz" target="_blank" rel="nofollow">www.hp.cz</A> -&gt; podpora a ovladače -&gt; zvolit stažení ovladačů, model designjet 500 -&gt; klik na konkrétní model -&gt; jazyk angličtina -&gt; Microsoft Windows 7 64 bit -&gt;získání software -&gt; vyplníte informace o Vás a pak by to mělo jít</P><P>Před několika dny jsem takhle stahoval ovladač pro HP800 ( je to&nbsp;společný ovladač pro 500, 510 a 800)</P><DIV>Co se týče ovladače pro 450C - viz Tip 5984 (VIP)</DIV>]]>
   <pubDate>Tue, 09 Mar 2010 13:42:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=10517&amp;PID=52051&amp;title=ovladac-hp-desingjet-500#52051</guid>
