  <title>CAD F&#243;rum : SEVERKA NAD RAZITKOM</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : SEVERKA NAD RAZITKOM]]></description>
  <pubDate>Wed, 04 Nov 2026 15:20:18 +0000</pubDate>
  <lastBuildDate>Fri, 17 Dec 2010 08:44:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=11963</WebWizForums:feedURL>
   <title><![CDATA[SEVERKA NAD RAZITKOM : TAKZE JA V PROJEKTE NEDOKAZEM...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57858&amp;title=severka-nad-razitkom#57858</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 17.pro.2010 v 08:44<br /><br />TAKZE JA V PROJEKTE NEDOKAZEM OKOTOVAT UHOL VACSI AKO 180°? MUSIM ZADAT KOTE PARAMETER ABY TO SLO V PROJEKTE?]]>
   <pubDate>Fri, 17 Dec 2010 08:44:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57858&amp;title=severka-nad-razitkom#57858</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : DAKUJEM.  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57857&amp;title=severka-nad-razitkom#57857</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 17.pro.2010 v 08:43<br /><br />DAKUJEM.&nbsp;]]>
   <pubDate>Fri, 17 Dec 2010 08:43:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57857&amp;title=severka-nad-razitkom#57857</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : Pokud kotujete, tak uhel v&#283;t&#353;&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57856&amp;title=severka-nad-razitkom#57856</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 17.pro.2010 v 08:42<br /><br />Pokud kotujete, tak uhel větší než 180° zřejmě nejde udělat. Jako parametr to problém není.<DIV></DIV>Odstranění přebytečných parametrů - klikněte na ikonu Family Types (vlevo nahoře), pak vyberte parametr a zvolte odstranit.]]>
   <pubDate>Fri, 17 Dec 2010 08:42:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57856&amp;title=severka-nad-razitkom#57856</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : prikladam obrazok. neviem tu kotu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57852&amp;title=severka-nad-razitkom#57852</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 17.pro.2010 v 08:00<br /><br />prikladam obrazok. neviem tu kotu predlzit na pozadovany uhol.<br>a v parametri popiska mam az tri a tie dva ostatne nedokazem zmazat.<br>dakujem<img src="uploads/20101217_080037_severka.jpg" height="498" width="497" border="0" /><br>]]>
   <pubDate>Fri, 17 Dec 2010 08:00:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57852&amp;title=severka-nad-razitkom#57852</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : severka sa otoci, to je v poriadku...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57851&amp;title=severka-nad-razitkom#57851</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 17.pro.2010 v 07:52<br /><br />severka sa otoci, to je v poriadku ale ja urobim kotu a tej zadam parameter, ale mne nejde urobit kota vseobecne 320°.<br>Revit nevie robit kotu 180 napriklad? Lebo ja urobim napriklad kotu 45°, ale tu kotu neviem pretiahnut do uhla 180°, popripade vacsiu.<br>]]>
   <pubDate>Fri, 17 Dec 2010 07:52:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57851&amp;title=severka-nad-razitkom#57851</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : Co v&#225;m nejde - ud&#283;lat k&#243;tu s hodnotou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57848&amp;title=severka-nad-razitkom#57848</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 16.pro.2010 v 16:19<br /><br />Co vám nejde - udělat kótu s hodnotou 320° jako parametr /pak ji udělejte třebas 20°a potom změňte hodnotu parametru/ nebo se vám nechce otočit severka při změně hodnoty parametru?]]>
   <pubDate>Thu, 16 Dec 2010 16:19:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57848&amp;title=severka-nad-razitkom#57848</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : MOZNO BLBA OTAZKA, ALE JA NEDOKAZEM...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57845&amp;title=severka-nad-razitkom#57845</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 16.pro.2010 v 14:32<br /><br />MOZNO BLBA OTAZKA, ALE JA NEDOKAZEM UROBIT KOTU NA 320°, STALE MI TU KOTU V TEJ RODINE DAVA INAK .....]]>
   <pubDate>Thu, 16 Dec 2010 14:32:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57845&amp;title=severka-nad-razitkom#57845</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : &#270;AKUJEM  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57844&amp;title=severka-nad-razitkom#57844</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 16.pro.2010 v 14:29<br /><br />ĎAKUJEM]]>
   <pubDate>Thu, 16 Dec 2010 14:29:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57844&amp;title=severka-nad-razitkom#57844</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM :   bielko napsal(a):V akej rodine,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57840&amp;title=severka-nad-razitkom#57840</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 16.pro.2010 v 13:11<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) bielko" alt="Původně odeslal(a) bielko" style="vertical-align: text-bottom;" /> <strong>bielko napsal(a):</strong><br /><br />V akej rodine, myslim aku sablonu ste pre rodinu pouzili? nieco obecne? dakujem</td></tr></table> Přesně tak, je to obecná popiska.]]>
   <pubDate>Thu, 16 Dec 2010 13:11:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57840&amp;title=severka-nad-razitkom#57840</guid>
   <title><![CDATA[SEVERKA NAD RAZITKOM : pridavam sem tu moju, no ma svoje...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57829&amp;title=severka-nad-razitkom#57829</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20160">bielko</a><br /><strong>Předmět:</strong> 11963<br /><strong>Zasláno:</strong> 16.pro.2010 v 10:19<br /><br />pridavam sem tu moju, no ma svoje muchy iba sa to ucim<a href="uploads/20101216_101847_vykres_s_rozpis.rfa" target="_blank" rel="nofollow">uploads/20101216_101847_vykres_s_rozpis.rfa.</a><br>tie ostatne parametre ktore tam mam naviac ani neviem zrusit<br>]]>
   <pubDate>Thu, 16 Dec 2010 10:19:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=11963&amp;PID=57829&amp;title=severka-nad-razitkom#57829</guid>
