  <title>CAD F&#243;rum : Uchopenie objektov</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Uchopenie objektov]]></description>
  <pubDate>Mon, 14 Sep 2026 04:46:48 +0000</pubDate>
  <lastBuildDate>Thu, 21 Apr 2011 10:18:53 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=12731</WebWizForums:feedURL>
   <title><![CDATA[Uchopenie objektov : Ve&#318;mi pekne &#271;akujem... ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60954&amp;title=uchopenie-objektov#60954</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20430">Punkbaster</a><br /><strong>Předmět:</strong> 12731<br /><strong>Zasláno:</strong> 21.dub.2011 v 10:18<br /><br />Vežmi pekne ďakujem...]]>
   <pubDate>Thu, 21 Apr 2011 10:18:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60954&amp;title=uchopenie-objektov#60954</guid>
   <title><![CDATA[Uchopenie objektov : Z&#345;ejm&#283; si pletete uchopen&#237; a vybr&#225;n&#237;. To,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60953&amp;title=uchopenie-objektov#60953</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=54">Seiner</a><br /><strong>Předmět:</strong> 12731<br /><strong>Zasláno:</strong> 21.dub.2011 v 10:16<br /><br />Zřejmě si pletete uchopení a vybrání.<DIV>To, co popisujete, řei PICKADD</DIV>]]>
   <pubDate>Thu, 21 Apr 2011 10:16:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60953&amp;title=uchopenie-objektov#60953</guid>
   <title><![CDATA[Uchopenie objektov : Odpov&#283;&#271; najdete v tipu &#269;. 3532...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60952&amp;title=uchopenie-objektov#60952</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=294">Pavel Homan</a><br /><strong>Předmět:</strong> 12731<br /><strong>Zasláno:</strong> 21.dub.2011 v 10:12<br /><br />Odpověď najdete v tipu č. <a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=3532" target="_blank">3532</A>]]>
   <pubDate>Thu, 21 Apr 2011 10:12:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60952&amp;title=uchopenie-objektov#60952</guid>
   <title><![CDATA[Uchopenie objektov : Pekn&#253; de&#328;. Ned&#225;vno sa mi pri pr&#225;ci...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60951&amp;title=uchopenie-objektov#60951</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20430">Punkbaster</a><br /><strong>Předmět:</strong> 12731<br /><strong>Zasláno:</strong> 21.dub.2011 v 10:07<br /><br />Pekný deň. Nedávno sa mi pri práci nejako preplo uchopenie objektov tak, e teraz moem ma uchopení len jeden objekt, akonáhle chcem uchopi aj druhy, tak mi ten prvý "vypne" a tak ďalej... Uchopenie viacerých objektov postupným zakliknutím u funguje len v kombinácii s klávesou SHIFT.&nbsp;<div>Udivuje ma to, lebo som sa s nastaveniami nehral u dos dlho, t.j. muselo sa to prepnú nedopatrením pri práci.</div><div>Máte radu ako získa naspa klasické uchopenie, pri ktorom si vyberám aj viacero objektov postupným kliknutím, bez toho aby som musel dra SHIFT?&nbsp;</div><div>Ďakujem :)</div>]]>
   <pubDate>Thu, 21 Apr 2011 10:07:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12731&amp;PID=60951&amp;title=uchopenie-objektov#60951</guid>
