  <title>CAD F&#243;rum : Čáry sítí - Autocad 2011</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Čáry sítí - Autocad 2011]]></description>
  <pubDate>Wed, 29 Jul 2026 19:35:03 +0000</pubDate>
  <lastBuildDate>Fri, 29 Apr 2011 09:14:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=12778</WebWizForums:feedURL>
   <title><![CDATA[Čáry sítí - Autocad 2011 : D&#237;ky, funguje ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61130&amp;title=cary-siti-autocad-2011#61130</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20892">pavel.schr</a><br /><strong>Předmět:</strong> 12778<br /><strong>Zasláno:</strong> 29.dub.2011 v 09:14<br /><br />Díky, funguje <img src="https://www.cadforum.cz/forum/smileys/smiley20.gif" border="0" align="middle" /> ]]>
   <pubDate>Fri, 29 Apr 2011 09:14:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61130&amp;title=cary-siti-autocad-2011#61130</guid>
   <title><![CDATA[Čáry sítí - Autocad 2011 : P&#345;e&#269;t&#283;te si pros&#237;m pokyny, kter&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61128&amp;title=cary-siti-autocad-2011#61128</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 12778<br /><strong>Zasláno:</strong> 29.dub.2011 v 09:01<br /><br />Přečtěte si prosím pokyny, které jsou uvedeny v PDF souboru čtimne.]]>
   <pubDate>Fri, 29 Apr 2011 09:01:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61128&amp;title=cary-siti-autocad-2011#61128</guid>
   <title><![CDATA[Čáry sítí - Autocad 2011 : D&#283;kuji, st&#225;hl jsem si z Va&#353;eho...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61127&amp;title=cary-siti-autocad-2011#61127</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20892">pavel.schr</a><br /><strong>Předmět:</strong> 12778<br /><strong>Zasláno:</strong> 29.dub.2011 v 08:59<br /><br />Děkuji, stáhl jsem si z Vašeho odkazu Cad standarty, ale co teď s tím, kam to zkopírovat? Jsem trochu počítačový amatér :-)]]>
   <pubDate>Fri, 29 Apr 2011 08:59:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61127&amp;title=cary-siti-autocad-2011#61127</guid>
   <title><![CDATA[Čáry sítí - Autocad 2011 : Dobr&#253; den,V&#225;&#353; probl&#233;m m&#367;&#382;e m&#237;t...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61126&amp;title=cary-siti-autocad-2011#61126</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 12778<br /><strong>Zasláno:</strong> 29.dub.2011 v 08:53<br /><br /><div style="border-top-width: 0px; border-right-width: 0px; border-bottom-width: 0px; border-left-width: 0px; border-style: initial; border-color: initial; : rgb(255, 255, 255); "><div style="color: rgb(48, 56, 63); font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-weight: normal; ">Dobrý den,</div><div style="color: rgb(48, 56, 63); font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-weight: normal; "><br></div><div style="color: rgb(48, 56, 63); font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12px; font-weight: normal; ">Váš problém může mít více příčin a to:</div><div><ul><li>chybějící soubor tvarů SHX,</li><li>špatně nastavené měřítko čar (proměnné LTSCALE, PSLTSCALE, MSLTSCALE).</li></ul><div>Soubory tvarů i definice čar inženýrských sítí najdete v <a href="http://www.cadforum.cz/cadforum/CAD-Standardy/" target="_blank">CAD standardech pro AutoCAD</a>.</div><div><br></div></div></div>]]>
   <pubDate>Fri, 29 Apr 2011 08:53:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61126&amp;title=cary-siti-autocad-2011#61126</guid>
   <title><![CDATA[Čáry sítí - Autocad 2011 : Zdrav&#237;m, v AC2011 se mi nezobrazuj&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61125&amp;title=cary-siti-autocad-2011#61125</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=20892">pavel.schr</a><br /><strong>Předmět:</strong> 12778<br /><strong>Zasláno:</strong> 29.dub.2011 v 08:47<br /><br />Zdravím, v AC2011 se mi nezobrazují čáry sítí správně (jsou to jen obyčejné plné čáry). Nevíte co udělat pro to, aby tomu tak nebylo? Potřebuji čáry kanalizace, vodovodu, plynu atd.. prostě vše, co je potřeba do koordinační situace. Děkuji]]>
   <pubDate>Fri, 29 Apr 2011 08:47:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12778&amp;PID=61125&amp;title=cary-siti-autocad-2011#61125</guid>
