  <title>CAD F&#243;rum : Další objekty na kouli</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Další objekty na kouli]]></description>
  <pubDate>Sat, 12 Sep 2026 04:30:42 +0000</pubDate>
  <lastBuildDate>Wed, 18 May 2011 13:04:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=12893</WebWizForums:feedURL>
   <title><![CDATA[Další objekty na kouli :   quadro4 napsal(a): &amp;lt;span...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61638&amp;title=dalsi-objekty-na-kouli#61638</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1030">Cheff</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 18.kvě.2011 v 13:04<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) quadro4" alt="Původně odeslal(a) quadro4" style="vertical-align: text-bottom;" /> <strong>quadro4 napsal(a):</strong><br /><br /><br />&lt;span ="universalsearch-bubble" id="UniversalSearchContextBubbleId" style="margin-top:-27px;"&gt;&lt;span ="universalsearch-bubble-" ="this.parentNode.style.opacity=1; if(this.parentNode.s && this.parentNode.s.alpha) this.parentNode.s.alpha.opacity=100;" ="this.parentNode.style.opacity=0.7;if(this.parentNode.s && this.parentNode.s.alpha) this.parentNode.s.alpha.opacity=70;" onstart="return false;" ondragstart="return false;"&gt;&lt;span ="universalsearch-bubble-icon universalsearch-clearfix"&gt;&lt;span ="universalsearch-bubble-iconrow universalsearch-clearfix"&gt;&lt;a ondragstart="return false;" ="universalsearch-bubble- universalsearch-bubble-icon-size-larger" ="return false;" id="BartUniversalSearch_ID_MoreSearches" cmdid="BartUniversalSearch_ID_MoreSearches" title="More searches..."&gt;<img src="chrome-extensi&#111;n://hmcgifbelcmjecmkapejifljephjabjd/images/accelerator-24.png" border="0" />&lt;/a&gt;&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;Můžu ještě radu , ja definovat ty roviny , mam kouli, ale ani za boha nemůžu ani jednu rovinu definovat...vždy potřebuje aspoň dva body ,ale kouli bohůžel bere jako jednu plochu.&lt;span ="yui-skin-sam" id="UniversalSearchContextBubbleMenuPlaceHolder"&gt;&lt;/span&gt;</td></tr></table> <br /><br />Jak píše kolega níže - stačí vybrat základní rovinu a pak kliknout na kulovou plochu - v ten okamžik vytvoří tečnou rovinu...  Nebo nedělat tečnou rovinu a zadefinovat si jakoukoli rovinu, která bude probíhat rovnoběžně s osou ostnu a ten potom orotovat (pokud bude dost "hluboko" pod povrch koule tak to vyjde podobně jako vysunutí kolmo k ploše...]]>
   <pubDate>Wed, 18 May 2011 13:04:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61638&amp;title=dalsi-objekty-na-kouli#61638</guid>
   <title><![CDATA[Další objekty na kouli : Ka&#382;d&#233; t&#283;leso m&#225; po&#269;&#225;tek. To je...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61608&amp;title=dalsi-objekty-na-kouli#61608</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=114">EuroTec</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 18.kvě.2011 v 08:06<br /><br />Každé těleso má počátek. To je tři roviny, tři osy a jeden bod. Co chcete víc?]]>
   <pubDate>Wed, 18 May 2011 08:06:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61608&amp;title=dalsi-objekty-na-kouli#61608</guid>
   <title><![CDATA[Další objekty na kouli :  M&#367;&#382;u je&#353;t&#283; radu , ja definovat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61593&amp;title=dalsi-objekty-na-kouli#61593</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33819">quadro4</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 17.kvě.2011 v 16:23<br /><br /><span ="universalsearch-bubble" id="UniversalSearchC&#111;ntextBubbleId" style="margin-top:-27px;"><span ="universalsearch-bubble-" ="this.parentNode.style.opacity=1; if(this.parentNode.s && this.parentNode.s.alpha) this.parentNode.s.alpha.opacity=100;" ="this.parentNode.style.opacity=0.7;if(this.parentNode.s && this.parentNode.s.alpha) this.parentNode.s.alpha.opacity=70;" &#111;nstart="return false;" &#111;ndragstart="return false;"><span ="universalsearch-bubble-ic&#111;n universalsearch-clearfix"><span ="universalsearch-bubble-ic&#111;nrow universalsearch-clearfix"><a &#111;ndragstart="return false;" ="universalsearch-bubble- universalsearch-bubble-ic&#111;n-size-larger" ="return false;" id="BartUniversalSearch_ID_MoreSearches" cmdid="BartUniversalSearch_ID_MoreSearches" title="More searches..."><img src="chrome-extensi&#111;n://hmcgifbelcmjecmkapejifljephjabjd/images/accelerator-24.png" border="0" /></a></span></span></span></span>Můžu ještě radu , ja definovat ty roviny , mam kouli, ale ani za boha nemůžu ani jednu rovinu definovat...vždy potřebuje aspoň dva body ,ale kouli bohůžel bere jako jednu plochu.<span ="yui-skin-sam" id="UniversalSearchC&#111;ntextBubbleMenuPlaceHolder"></span>]]>
   <pubDate>Tue, 17 May 2011 16:23:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61593&amp;title=dalsi-objekty-na-kouli#61593</guid>
   <title><![CDATA[Další objekty na kouli :  D&#237;ky za rady ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61578&amp;title=dalsi-objekty-na-kouli#61578</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33819">quadro4</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 17.kvě.2011 v 13:12<br /><br />Díky za rady&nbsp;<img src="https://www.cadforum.cz/forum/smileys/smiley32.gif" border="0" align="absmiddle" alt="Clap" /><span ="yui-skin-sam" id="UniversalSearchC&#111;ntextBubbleMenuPlaceHolder"></span>]]>
   <pubDate>Tue, 17 May 2011 13:12:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61578&amp;title=dalsi-objekty-na-kouli#61578</guid>
   <title><![CDATA[Další objekty na kouli : Nebo jednodu&#353;e vysunout ze st&#345;edu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61574&amp;title=dalsi-objekty-na-kouli#61574</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=1030">Cheff</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 17.kvě.2011 v 12:45<br /><br />Nebo jednoduše vysunout ze středu (pokud se jedná např o "válce" (případně si pomoci zúžením)<br />Ale základ je opravdu zadefinovat si nové roviny. <br /><br />Možností je spousty]]>
   <pubDate>Tue, 17 May 2011 12:45:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61574&amp;title=dalsi-objekty-na-kouli#61574</guid>
   <title><![CDATA[Další objekty na kouli : zkusil bych to p&#345;es nov&#283; nadefinovan&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61570&amp;title=dalsi-objekty-na-kouli#61570</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25745">Fiki</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 17.kvě.2011 v 11:59<br /><br />zkusil bych to přes nově nadefinované roviny tečně na plodu od zakladních ploch tělesa. INV 2011 dokáže definovat plochy pod všemy úhly.&nbsp;]]>
   <pubDate>Tue, 17 May 2011 11:59:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61570&amp;title=dalsi-objekty-na-kouli#61570</guid>
   <title><![CDATA[Další objekty na kouli : Zdrav&#237;m , pot&#345;eboval bych radu,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61569&amp;title=dalsi-objekty-na-kouli#61569</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=33819">quadro4</a><br /><strong>Předmět:</strong> 12893<br /><strong>Zasláno:</strong> 17.kvě.2011 v 11:39<br /><br />Zdravím , potřeboval bych radu, jak docílím toho , abych na hotovém tělesu - koule mohl vytvářet další objekty.Jedná se mi přímo o nakreslení ježka, ze známého hlavolamu "ježek v kleci". Prosím o radu moc moc :-)]]>
   <pubDate>Tue, 17 May 2011 11:39:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=12893&amp;PID=61569&amp;title=dalsi-objekty-na-kouli#61569</guid>
