  <title>CAD F&#243;rum : orezanie solidu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : orezanie solidu]]></description>
  <pubDate>Fri, 04 Sep 2026 13:22:06 +0000</pubDate>
  <lastBuildDate>Thu, 22 Sep 2011 13:15:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=13602</WebWizForums:feedURL>
   <title><![CDATA[orezanie solidu : Dakujem, pomohlo :) ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64416&amp;title=orezanie-solidu#64416</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4658">DodoSVK</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 13:15<br /><br />Dakujem, pomohlo :)]]>
   <pubDate>Thu, 22 Sep 2011 13:15:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64416&amp;title=orezanie-solidu#64416</guid>
   <title><![CDATA[orezanie solidu : Zkuste zv&#253;&#353;it toleranci mezer...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64415&amp;title=orezanie-solidu#64415</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 13:09<br /><br />Zkuste zvýšit toleranci mezer - HPGAPTOL, viz tip:<DIV><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=3612" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=3612</A></DIV>]]>
   <pubDate>Thu, 22 Sep 2011 13:09:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64415&amp;title=orezanie-solidu#64415</guid>
   <title><![CDATA[orezanie solidu : Solid pouzivam namiestach, kde...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64411&amp;title=orezanie-solidu#64411</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4658">DodoSVK</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 12:40<br /><br />Solid pouzivam na&nbsp;miestach, kde by sa dala pouzit presne ako pisete srafa typu solid. Radsej pouzivam prave srafu, no ked mam objekt ktory chcem vyfarbit zlozity zlozeny z mnozstva malych polylines a entit typu arc a podobne, srafa ma stym dost problemy. Nevie rozpoznat hranice, zamrza mi cad a podobne, vtedy pracne taku plochu vyfarbujem solidom. :(<DIV>&nbsp;</DIV><DIV>MOzno by pomohli neake tipy ako efektivnejsie vyuzivat srafu ked v hraniciach ktore jej oznacim su male medzierky, ktore na prvy pohlad nevidim, alebo podobne male nedostatky, &nbsp;a hranice sa mne zdaju v poriadku no CAD mi tam srafu nechce dat :(</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 22 Sep 2011 12:40:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64411&amp;title=orezanie-solidu#64411</guid>
   <title><![CDATA[orezanie solidu : Dnes sa SOLID u&#382; d&#225; nahradi&#357; &#353;rafou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64406&amp;title=orezanie-solidu#64406</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=762">Buba</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 10:20<br /><br />Dnes sa SOLID už dá nahradiť šrafou štýlu SOLID. <DIV>Ale v starých verziách taký šrafovací&nbsp;vzor nebol.</DIV><span style="font-size:10px"><br /><br />Upravil Buba - 22.zář.2011 v 10:21</span>]]>
   <pubDate>Thu, 22 Sep 2011 10:20:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64406&amp;title=orezanie-solidu#64406</guid>
   <title><![CDATA[orezanie solidu : Dnes u&#382; se moc nepou&#382;&#237;v&#225;, ale...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64405&amp;title=orezanie-solidu#64405</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 09:41<br /><br />Dnes už se moc nepoužívá, ale je to hodně "lightweight" entita s rychlým zobrazením. Dříve se používala např. na vyplnění ploch celobarevnou výplní. Využívá se také např. pro zobrazení jednotlivých "pixelů" obrázku v naší aplikaci <a href="http://www.cadstudio.cz/imgc&#111;nvert" target="_blank">ImgConvert</A>.]]>
   <pubDate>Thu, 22 Sep 2011 09:41:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64405&amp;title=orezanie-solidu#64405</guid>
   <title><![CDATA[orezanie solidu :   Na co je v&#367;bec dobr&#253; 2D solid,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64404&amp;title=orezanie-solidu#64404</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 22.zář.2011 v 09:28<br /><br />Na co je vůbec dobrý 2D solid, kde taková entita nachází použití?]]>
   <pubDate>Thu, 22 Sep 2011 09:28:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64404&amp;title=orezanie-solidu#64404</guid>
   <title><![CDATA[orezanie solidu : 2D Solid je dost specifick&#253; typ...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64399&amp;title=orezanie-solidu#64399</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 21.zář.2011 v 17:15<br /><br />2D Solid je dost specifický typ entity, běžné ořezávací operace tam asi fungovat nebudou.]]>
   <pubDate>Wed, 21 Sep 2011 17:15:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64399&amp;title=orezanie-solidu#64399</guid>
   <title><![CDATA[orezanie solidu :   D&#345;&#237;ve fungovalo i _slice (pomoc&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64398&amp;title=orezanie-solidu#64398</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 21.zář.2011 v 16:36<br /><br />Dříve fungovalo i _slice (pomocí 3 bodů), snad to tam kluci nechali.]]>
   <pubDate>Wed, 21 Sep 2011 16:36:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64398&amp;title=orezanie-solidu#64398</guid>
   <title><![CDATA[orezanie solidu : myslel som prave 2D solid. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64397&amp;title=orezanie-solidu#64397</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4658">DodoSVK</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 21.zář.2011 v 16:36<br /><br />myslel som prave 2D solid. ]]>
   <pubDate>Wed, 21 Sep 2011 16:36:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64397&amp;title=orezanie-solidu#64397</guid>
   <title><![CDATA[orezanie solidu : Mysl&#237;te 2D solid (desku) nebo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64396&amp;title=orezanie-solidu#64396</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 13602<br /><strong>Zasláno:</strong> 21.zář.2011 v 16:32<br /><br /><P>Myslíte 2D solid (desku) nebo 3D solid (objemové těleso)? 3D těleso jde oříznout jiným 3D tělesem (např. křivkou vytaženou do 3D).</P>]]>
   <pubDate>Wed, 21 Sep 2011 16:32:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=13602&amp;PID=64396&amp;title=orezanie-solidu#64396</guid>
