  <title>CAD F&#243;rum : Hotfix pro AutoCAD 2011 - plochy</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Hotfix pro AutoCAD 2011 - plochy]]></description>
  <pubDate>Fri, 03 Jul 2026 17:18:26 +0000</pubDate>
  <lastBuildDate>Thu, 08 Dec 2011 12:00:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=14097</WebWizForums:feedURL>
   <title><![CDATA[Hotfix pro AutoCAD 2011 - plochy : Tenhle probl&#233;m se mysl&#237;m ve verzi...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66412&amp;title=hotfix-pro-autocad-2011-plochy#66412</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 14097<br /><strong>Zasláno:</strong> 08.pro.2011 v 12:00<br /><br />Tenhle problém se myslím ve verzi 2012 nevyskytuje.]]>
   <pubDate>Thu, 08 Dec 2011 12:00:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66412&amp;title=hotfix-pro-autocad-2011-plochy#66412</guid>
   <title><![CDATA[Hotfix pro AutoCAD 2011 - plochy :   V acad2012 u&#382; ten probl&#233;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66409&amp;title=hotfix-pro-autocad-2011-plochy#66409</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 14097<br /><strong>Zasláno:</strong> 08.pro.2011 v 11:31<br /><br />V acad2012 už ten problém není? Nebo je opraven v SP1?]]>
   <pubDate>Thu, 08 Dec 2011 11:31:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66409&amp;title=hotfix-pro-autocad-2011-plochy#66409</guid>
   <title><![CDATA[Hotfix pro AutoCAD 2011 - plochy : Ofici&#225;ln&#283; je to jen pro AutoCAD,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66400&amp;title=hotfix-pro-autocad-2011-plochy#66400</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 14097<br /><strong>Zasláno:</strong> 08.pro.2011 v 08:50<br /><br />Oficiálně je to jen pro AutoCAD, a vzhledem k tomu že součástí patche je i EXE soubor, v jiných verzích to zřejmě použít nepůjde.]]>
   <pubDate>Thu, 08 Dec 2011 08:50:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66400&amp;title=hotfix-pro-autocad-2011-plochy#66400</guid>
   <title><![CDATA[Hotfix pro AutoCAD 2011 - plochy : P&#345;esn&#283; to z popisu chyby nevid&#237;m,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66398&amp;title=hotfix-pro-autocad-2011-plochy#66398</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 14097<br /><strong>Zasláno:</strong> 08.pro.2011 v 08:45<br /><br />Přesně to z popisu chyby nevidím, ale týká se to jen holého AutoCadu, nebo i MAP 2011?<br>Jak přesně se chyba projevovala?<br>]]>
   <pubDate>Thu, 08 Dec 2011 08:45:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66398&amp;title=hotfix-pro-autocad-2011-plochy#66398</guid>
   <title><![CDATA[Hotfix pro AutoCAD 2011 - plochy : Byl vyd&#225;n nov&#253; hotfix pro AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66393&amp;title=hotfix-pro-autocad-2011-plochy#66393</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 14097<br /><strong>Zasláno:</strong> 08.pro.2011 v 08:15<br /><br />Byl vydán nový hotfix pro AutoCAD 2011 SP2 - opravuje výpočet plochy pro křivky ležící ve velké vzdálenosti od počátku (např. v JTSK). Viz:<DIV><a href="http://usa.autodesk.com/getdoc/id=DL18225251" target="_blank" rel="nofollow">http://usa.autodesk.com/getdoc/id=DL18225251</A></DIV>]]>
   <pubDate>Thu, 08 Dec 2011 08:15:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=14097&amp;PID=66393&amp;title=hotfix-pro-autocad-2011-plochy#66393</guid>
