  <title>CAD F&#243;rum : Prevod .VLX pripadne .LSP do .ARX.....?</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD programov&#225;n&#237; : Prevod .VLX pripadne .LSP do .ARX.....?]]></description>
  <pubDate>Mon, 17 Aug 2026 07:28:47 +0000</pubDate>
  <lastBuildDate>Wed, 08 Jun 2005 15:04:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=161</WebWizForums:feedURL>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : VLX do LSP je dekompilace, tu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=3824&amp;title=prevod-vlx-pripadne-lsp-do-arx#3824</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 08.čer.2005 v 15:04<br /><br />VLX do LSP je <strong>de</strong>kompilace, tu žádný nástroj neumí]]>
   <pubDate>Wed, 08 Jun 2005 15:04:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=3824&amp;title=prevod-vlx-pripadne-lsp-do-arx#3824</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : A um&#237; ten SharpLisp rekompilovat...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=3818&amp;title=prevod-vlx-pripadne-lsp-do-arx#3818</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46">Ferdinand</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 08.čer.2005 v 14:18<br /><br />A umí ten SharpLisp rekompilovat <span style="color: rgb(0, 0, 255);">vlx</span> zpět do <span style="color: rgb(0, 0, 255);">lsp </span>?<br><br>]]>
   <pubDate>Wed, 08 Jun 2005 14:18:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=3818&amp;title=prevod-vlx-pripadne-lsp-do-arx#3818</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Dobry den, SharpLisp - dobry...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=452&amp;title=prevod-vlx-pripadne-lsp-do-arx#452</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=31">Jan Liska</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 10.lis.2004 v 08:27<br /><br /><P>Dobry den,</P><P>SharpLisp - dobry tip, o tom jsem skutecne nevedel.</P><P>Co se tyka rychlosti, zalezi na tom, co konkretne vas LISP program provadi - pokud napr. velmi casto volate (command "_line"), tak muzete zkusit toto nahradit volanim funkce (entmake).</P><P>Jak jiz psal Vl.Michl, prepsani do C++ obvykle neni zcela trivialni, zalezi na funkcnosti (napr. prepsani dialogu z DCL do MFC muze znamenat vytvoreni zcela noveho kodu).</P><P>S pozdravem</P>]]>
   <pubDate>Wed, 10 Nov 2004 08:27:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=452&amp;title=prevod-vlx-pripadne-lsp-do-arx#452</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Co si clovek nezjisti sam, to...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=451&amp;title=prevod-vlx-pripadne-lsp-do-arx#451</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=217">Darq</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 10.lis.2004 v 06:51<br /><br />Co si clovek nezjisti sam, to nema :). http://www.objectdcl.com/SharpLisp.html ]]>
   <pubDate>Wed, 10 Nov 2004 06:51:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=451&amp;title=prevod-vlx-pripadne-lsp-do-arx#451</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Pro zpomalen&#237; VLX oproti FAS nebo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=447&amp;title=prevod-vlx-pripadne-lsp-do-arx#447</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 09.lis.2004 v 16:10<br /><br /><P>Pro zpomalení VLX oproti FAS nebo dokonce LSP není důvod. VLX i FAS jsou předkompilované LSP.</P><P>Přepsání LISP aplikace do C++ není triviální a asi těžko můžete očekávat "přesnější postup". Jsou to dva různé (hodně odlišné) programovací jazyky. Prostě by se dotyčná rutina musela naprogramovat znovu v daném jazyku.</P>]]>
   <pubDate>Tue, 09 Nov 2004 16:10:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=447&amp;title=prevod-vlx-pripadne-lsp-do-arx#447</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Diky, ale tohle vsechno vim :)....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=444&amp;title=prevod-vlx-pripadne-lsp-do-arx#444</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=217">Darq</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 09.lis.2004 v 15:17<br /><br /><P>Diky, ale tohle vsechno vim :). Problem je v rychlosti - .vlx se mi zda podstatne pomalejsi nez .fas nebo .lsp - vzhledem k tomu, ze tech .lsp souboru mam 20+, bylo by vhodne zkompilovat je do jednoho, ale bez toho zpomaleni. Co obnasi prepsani .lsp do C++? Jak moc se ten zapis lisi? Potrebuju presnejsi postup, pripadne doporuceni nevhodnejsi varianty. </P><P>dik</P><span style="font-size:10px"><br /><br />Upravil Darq</span>]]>
   <pubDate>Tue, 09 Nov 2004 15:17:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=444&amp;title=prevod-vlx-pripadne-lsp-do-arx#444</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Dobry den, obavam se, ze zcela...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=443&amp;title=prevod-vlx-pripadne-lsp-do-arx#443</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=31">Jan Liska</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 09.lis.2004 v 14:50<br /><br /><P>Dobry den,</P><P>obavam se, ze zcela jednoduche reseni neexistuje - ARX je kompilovana aplikace psana v C++, zatimco VLX je LISP.</P><P>Pokud vse funguje jak ma, neni pravdepodobne duvod to menit :-) Pokud narazite na nejaka omezeni (funcnost, rychlost, stabilita atd.), doporucuji zvazit prepsani do ARX, pripadne vyuzit mezistupen VBA, popr. .Net. Muzete take vytvorit aplikaci, kde cast bude psana v C++ (=ARX) a cast zustane v LISPu (=VLX).</P><P>S pozdravem</P>]]>
   <pubDate>Tue, 09 Nov 2004 14:50:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=443&amp;title=prevod-vlx-pripadne-lsp-do-arx#443</guid>
   <title><![CDATA[Prevod .VLX pripadne .LSP do .ARX.....? : Vite nekdo, jak vytvorit z LISPove...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=440&amp;title=prevod-vlx-pripadne-lsp-do-arx#440</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=217">Darq</a><br /><strong>Předmět:</strong> 161<br /><strong>Zasláno:</strong> 09.lis.2004 v 14:25<br /><br /><P>Vite nekdo, jak vytvorit z LISPove aplikace, slozene se souboru .lsp a .dcl, jeden soubor .arx? </P><P>Dik&nbsp;&nbsp;</P>]]>
   <pubDate>Tue, 09 Nov 2004 14:25:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=161&amp;PID=440&amp;title=prevod-vlx-pripadne-lsp-do-arx#440</guid>
