  <title>CAD F&#243;rum : GG menu, AR menu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : GG menu, AR menu]]></description>
  <pubDate>Thu, 03 Sep 2026 17:54:24 +0000</pubDate>
  <lastBuildDate>Wed, 21 Nov 2012 18:02:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=16156</WebWizForums:feedURL>
   <title><![CDATA[GG menu, AR menu : Dobr&#253; ve&#269;er,v &#269;em byl pros&#237;m nakonec...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74255&amp;title=gg-menu-ar-menu#74255</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 21.lis.2012 v 18:02<br /><br />Dobrý večer,<div><br></div><div>v čem byl prosím nakonec problém?</div>]]>
   <pubDate>Wed, 21 Nov 2012 18:02:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74255&amp;title=gg-menu-ar-menu#74255</guid>
   <title><![CDATA[GG menu, AR menu : Chyba nalezena:-) D&#237;ky:-) ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74247&amp;title=gg-menu-ar-menu#74247</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=45456">Petshi</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 21.lis.2012 v 15:59<br /><br />Chyba nalezena:-) Díky:-)]]>
   <pubDate>Wed, 21 Nov 2012 15:59:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74247&amp;title=gg-menu-ar-menu#74247</guid>
   <title><![CDATA[GG menu, AR menu : P&#237;&#353;e mi to load selhal. Zkus&#237;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74246&amp;title=gg-menu-ar-menu#74246</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=45456">Petshi</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 21.lis.2012 v 15:38<br /><br />Píše mi to load selhal. Zkusím to znovu nahrát.]]>
   <pubDate>Wed, 21 Nov 2012 15:38:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74246&amp;title=gg-menu-ar-menu#74246</guid>
   <title><![CDATA[GG menu, AR menu : Funkci v&#253;&#353;kov&#253;ch k&#243;t m&#367;&#382;ete snadno...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74188&amp;title=gg-menu-ar-menu#74188</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=161">alfred</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 20.lis.2012 v 20:43<br /><br />Funkci výškových kót můžete snadno vyzkoušet i bez ikonek. <br>Načtěte si utilitu "kotvysk.lsp"<br>příkazy jsou pak: <br>"VKS" Výšková kóta - vkládá blok 'Kota_vysky_R_GG' nebo 'Kota_vysky_R_GG.dwg'<br>VKS-POLE" Výšková kóta s polem - automaticky je v poli zobrazena souradnice Y mista vlozeni bloku. Vklada blok 'Kota_vysky_R_GG-POLE' (Kota_vysky_R_GG-POLE.dwg). U tohoto bloku se pro kladne hodnoty NEZOBRAZUJE znamenko "+".<br>"VKO" Oprava hodnoty výškové kóty "Kota_vysky_R_GG" a predchozich "vk1, vk2, ... vk8, vkota, KOTAVYSK"<br>"VKNULA" Nastaví počátek (0,000) pro kótování<br>"VKNULAZPET" Vrátí počátek (0,000) zpět na původní hodnotu<br>"VKS-NADM" - přidána funkce, která vkládá kótu bez úvodního plusu<br><br>]]>
   <pubDate>Tue, 20 Nov 2012 20:43:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74188&amp;title=gg-menu-ar-menu#74188</guid>
   <title><![CDATA[GG menu, AR menu : Dobr&#253; den,ARmenu ke sta&#382;en&#237; pravd&#283;podobn&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74183&amp;title=gg-menu-ar-menu#74183</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 20.lis.2012 v 19:00<br /><br />Dobrý den,<div><br></div><div>ARmenu ke stažení pravděpodobně již nenaleznete. Jednalo se o nadstavbu vytvořenou pracovníky S-Projektu, která s používala na stavební průmyslovce ve Zlíně a kdysi dávno jsem ji viděl ke stažení na stránkách studenta též průmyslovky.</div><div><br></div><div>Pokud Vám v GGmenu blikají ikonky při spuštění funkce, podívejte se prosím do příkazového řádku, co za hlášku hlásí. Pravděpodobně máte špatně nastaveny cesty k podpůrným souborům nebo Vám chybí blok výškové kóty.</div>]]>
   <pubDate>Tue, 20 Nov 2012 19:00:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74183&amp;title=gg-menu-ar-menu#74183</guid>
   <title><![CDATA[GG menu, AR menu : Cht&#283;la bych se pros&#237;m zeptat,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74182&amp;title=gg-menu-ar-menu#74182</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=45456">Petshi</a><br /><strong>Předmět:</strong> 16156<br /><strong>Zasláno:</strong> 20.lis.2012 v 18:34<br /><br />Chtěla bych se prosím zeptat, kde mohu najít nadstavbu AR menu?<div>Nebo nevíte co s GG menu když chci dát např. výškovou kótu tak mi začnou ikonky blikat a až po zmáčknutí esc to přestane,ale kótu to neudělá.</div><div>Děkuji&nbsp;<br><div><br></div></div>]]>
   <pubDate>Tue, 20 Nov 2012 18:34:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16156&amp;PID=74182&amp;title=gg-menu-ar-menu#74182</guid>
