  <title>CAD F&#243;rum : Stropne svetlo</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Stropne svetlo]]></description>
  <pubDate>Mon, 17 Aug 2026 16:32:10 +0000</pubDate>
  <lastBuildDate>Mon, 18 Mar 2013 09:52:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=16829</WebWizForums:feedURL>
   <title><![CDATA[Stropne svetlo : https://chronicle.autodesk.com...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76889&amp;title=stropne-svetlo#76889</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 16829<br /><strong>Zasláno:</strong> 18.bře.2013 v 09:52<br /><br />https://chronicle.autodesk.com/Main/Details/fc69a8a1-06b7-46c0-af58-54c784b12a4d<div><br></div><div>Zkouším Chronicle :-)</div>]]>
   <pubDate>Mon, 18 Mar 2013 09:52:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76889&amp;title=stropne-svetlo#76889</guid>
   <title><![CDATA[Stropne svetlo : A m&#225;te tam strop/podhld (ceiling)...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76865&amp;title=stropne-svetlo#76865</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 16829<br /><strong>Zasláno:</strong> 16.bře.2013 v 15:44<br /><br />A máte tam strop/podhld (ceiling) nebo spodní rovinu stropní desky (floor)?]]>
   <pubDate>Sat, 16 Mar 2013 15:44:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76865&amp;title=stropne-svetlo#76865</guid>
   <title><![CDATA[Stropne svetlo : ja vlastne vyberiem komponentu-stropne...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76858&amp;title=stropne-svetlo#76858</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=47442">modrybaron</a><br /><strong>Předmět:</strong> 16829<br /><strong>Zasláno:</strong> 15.bře.2013 v 21:51<br /><br />ja vlastne vyberiem komponentu-stropne svetlo, ale neda sa mi umiestnit na strop ani nikde inde... nemozem ho vobec osadit na strop, tam je ten problem...upravy svetelneho efektu atd. by uz nebol taky problem, len pokial nemam to svetlo vobec tak s nim nemozem nic robit&nbsp;]]>
   <pubDate>Fri, 15 Mar 2013 21:51:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76858&amp;title=stropne-svetlo#76858</guid>
   <title><![CDATA[Stropne svetlo : Pod&#237;vejte se nejd&#345;&#237;ve do rodiny,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76852&amp;title=stropne-svetlo#76852</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 16829<br /><strong>Zasláno:</strong> 15.bře.2013 v 20:19<br /><br />Podívejte se nejdříve do rodiny, na co se má daná rodina chytat (wall, face, ceiling nebo nic), podle toho zvolte v projektu, čeho se má chytit, pak je taky si dát pozor na volbu pracovní rovina/vertikální rovina/face aby se nechytalo něčeho jiného. Světlo se nedá vložit nebo nevidíte kam se vloží?]]>
   <pubDate>Fri, 15 Mar 2013 20:19:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76852&amp;title=stropne-svetlo#76852</guid>
   <title><![CDATA[Stropne svetlo : mohli by ste mi poradit ako vlozim...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76850&amp;title=stropne-svetlo#76850</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=47442">modrybaron</a><br /><strong>Předmět:</strong> 16829<br /><strong>Zasláno:</strong> 15.bře.2013 v 19:24<br /><br />mohli by ste mi poradit ako vlozim do interieru stropne svetlo?<img src="http://www.cadforum.cz/forum/smileys/smiley29.gif" border="0" alt="Wacko" title="Wacko" /><img src="http://www.cadforum.cz/forum/smileys/smiley29.gif" border="0" alt="Wacko" title="Wacko" /><img src="http://www.cadforum.cz/forum/smileys/smiley29.gif" border="0" alt="Wacko" title="Wacko" />...nastenne a stojace su v pohode, ale nemozem to svetlo uchytit na strop ani v podoryse, ani v reze, ani v podoryse stropu a uz asi 2 hodiny hladam po nete nejake riesenia, ale nic co som skusal nefunguje&nbsp;<img src="https://www.cadforum.cz/forum/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />&nbsp;...dakujem za co najrychlejsiu odpoved]]>
   <pubDate>Fri, 15 Mar 2013 19:24:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=16829&amp;PID=76850&amp;title=stropne-svetlo#76850</guid>
