  <title>CAD F&#243;rum : Inventor 2014 Update 2</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Inventor 2014 Update 2]]></description>
  <pubDate>Sun, 26 Jul 2026 05:32:33 +0000</pubDate>
  <lastBuildDate>Wed, 10 Jul 2013 08:14:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=17481</WebWizForums:feedURL>
   <title><![CDATA[Inventor 2014 Update 2 : Pro u&#382;ivatele Inventoru 2014 byl...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=17481&amp;PID=79337&amp;title=inventor-2014-update-2#79337</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 17481<br /><strong>Zasláno:</strong> 10.čvc.2013 v 08:14<br /><br />Pro uživatele Inventoru 2014 byl uvolněn hotfix "Update 2" - <a href="http://usa.autodesk.com/getdoc/id=DL21901957" target="_blank" rel="nofollow">http://usa.autodesk.com/getdoc/id=DL21901957</A><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>Obsahuje i opravy z "Update 1", je určen pro samostatný Inventor i sady Design Suite&nbsp;2014 a opravuje následující chyby:</DIV><DIV>&nbsp;</DIV><DIV><LI><P =Alt>Older VBA code is not working properly </P><LI><P =Alt>Shaded views are not showing correct in drawing with zoom </P><LI><P =Alt>Inconsistant behavior when Copy and Paste of components where file path is long </P><LI><P =Alt>Layout constraint context menu command is missing </P><LI><P =Alt>One side of brake line show unshaded when creating break in a shaded projected view </P><LI><P =Alt>Bolted connection is not able to machine more than two parts at the same time </P><LI><P =Alt>Unexpected exit when Loading idw </P><LI><P =Alt>Stability enhancement </P><DIV><strong>Update 1:<BR></strong></DIV></LI></DIV><LI><P =Alt>Many duplicate occurrences shown in browser of IPN's following assembly demote/promote </P><LI><P =Alt>Create New dialog does not remember the size and order of column in details view </P><LI><P =Alt>Mass property is not available after migration </P><LI><P =Alt>Min and Max values for Hole patching are not stored </P><LI><P =Alt>View remains raster after selecting Precise view </P><LI><P =Alt>iFeature insert dialog will show "Create Package" instead of the description of the iFeature </P><LI><P =Alt>Copying a material in the category will corrupt that material from the library </P><LI><P =Alt>Unable to change icon of existing custom category in Content Center Library </P><LI><P =Alt>Adding a material will flag existing file as out of date and unnecessarily replace/update appearances </P><LI><P =Alt>Weldment iAssemblies still looking for the obsolete "Use as Weldment Material" setting </P><LI><P =Alt>Highlight effect when mouse hover on geometry is not as good as full mode when create Dimension/Baseline/Ordinate annotation in Raster View </P><LI><P =Alt>GraphicsNode.RenderStyle has no effect on the graphics entity </P><LI><P =Alt>The translator addin imports the DWG into sketch with wrong units if custom units specified </P><LI><P =Alt>Legacy Section View displays incorrect line </P><LI><P =Alt>Title block incorrectly displayed on Zoom when multiple files opened </P><LI><P =Alt>Decreased performance when selecting all assets </P><LI><P =Alt>Decreased performance when select Derive menu Other Tab </P><LI><P =Alt>Slow shut down of InventorViewCompute.exe even after Inventor main window closes </P><LI><P =Alt>Unexpected exit when make all views raster and make all views precise </P><LI><P =Alt>Unexpected exit when switching to Full from Express mode </P><LI><P =Alt>Unexpected exit when click adjust with customized project setting </P><LI><P =Alt>Unexpected exit when rotating large assembly </P><LI><P =Alt>Unexpected exit when dragging materials in user library </P><LI><P =Alt>Unexpected exit when Load Express </P><LI><P =Alt>Unexpected exit when starting Inventor from Factory Design Suite </P><LI><P =Alt>Unexpected exit due to Non-transacted AddTriangleGraphics </P></LI>]]>
   <pubDate>Wed, 10 Jul 2013 08:14:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=17481&amp;PID=79337&amp;title=inventor-2014-update-2#79337</guid>
