  <title>CAD F&#243;rum : nelze otevírat</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : nelze otevírat]]></description>
  <pubDate>Sat, 05 Sep 2026 02:12:32 +0000</pubDate>
  <lastBuildDate>Thu, 29 Aug 2013 22:50:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=17817</WebWizForums:feedURL>
   <title><![CDATA[nelze otevírat : update na SP2 pomohl. probl&#233;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80169&amp;title=nelze-otevirat#80169</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46077">listrmistr</a><br /><strong>Předmět:</strong> 17817<br /><strong>Zasláno:</strong> 29.srp.2013 v 22:50<br /><br />update na SP2 pomohl. problém vyřešen děkuji za radu<br>]]>
   <pubDate>Thu, 29 Aug 2013 22:50:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80169&amp;title=nelze-otevirat#80169</guid>
   <title><![CDATA[nelze otevírat :   ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80168&amp;title=nelze-otevirat#80168</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46077">listrmistr</a><br /><strong>Předmět:</strong> 17817<br /><strong>Zasláno:</strong> 29.srp.2013 v 22:41<br /><br /><img src="uploads/46077/Bez_názvu.jpg" height="737" width="536" border="0" />]]>
   <pubDate>Thu, 29 Aug 2013 22:41:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80168&amp;title=nelze-otevirat#80168</guid>
   <title><![CDATA[nelze otevírat :  M&#225;te nainstalovan&#253; SP2 pro AutoCAD?...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80161&amp;title=nelze-otevirat#80161</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 17817<br /><strong>Zasláno:</strong> 29.srp.2013 v 14:55<br /><br />Máte nainstalovaný SP2 pro AutoCAD? AutoCAD 2013 je oficiálně kompatibilní s Win8 až od service packu 2 - viz <a href="http://www.cadforum.cz/cadforum/aplikace-autodesk-kompatibilni-s-os-windows-8-tip8899">http://www.cadforum.cz/cadforum/aplikace-autodesk-kompatibilni-s-os-windows-8-tip8899</a><div></div><div>Jak zní ta chybová hláška?</div>]]>
   <pubDate>Thu, 29 Aug 2013 14:55:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80161&amp;title=nelze-otevirat#80161</guid>
   <title><![CDATA[nelze otevírat : &#269;au v&#353;em, m&#225;m takov&#253; specifick&#253;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80159&amp;title=nelze-otevirat#80159</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=46077">listrmistr</a><br /><strong>Předmět:</strong> 17817<br /><strong>Zasláno:</strong> 29.srp.2013 v 14:16<br /><br />čau všem, mám takový specifický problém, mám win 8 a nainstalovaný AutoCAD 2013 když jsem ho nainstaloval tak jsem asi 2x sputil vše normálně i vypracovaný dwg soubor jsem otevřel, ale teď když chci otevřít dwg soubor tak mi to vyhodí hlášku o pádu a kontaktování firmy autodesk. Když ale otevřu čistý, nový výkres a dám otevřít soubor dwg tak vše jde v pořádku. nelze mi jen otevřít soubor přímo přes ikonu souboru... prosím o radu<br>]]>
   <pubDate>Thu, 29 Aug 2013 14:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=17817&amp;PID=80159&amp;title=nelze-otevirat#80159</guid>
