  <title>CAD F&#243;rum : LISP - aktualizacia datumu jednoriadkoveho textu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : LISP - aktualizacia datumu jednoriadkoveho textu]]></description>
  <pubDate>Wed, 09 Sep 2026 00:26:59 +0000</pubDate>
  <lastBuildDate>Wed, 02 Oct 2013 17:23:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18008</WebWizForums:feedURL>
   <title><![CDATA[LISP - aktualizacia datumu jednoriadkoveho textu : ja som sa to pokusal vlozit do...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80777&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80777</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51727">hazometer</a><br /><strong>Předmět:</strong> 18008<br /><strong>Zasláno:</strong> 02.říj.2013 v 17:23<br /><br />ja som sa to pokusal vlozit do uz existujuceho lispu, ktory pouzivam(e):<br><br>;MAKE a block ... possibility of selecting text from screen<br>(defun c:MB&nbsp;&nbsp;&nbsp;&nbsp; ()<br>(command&nbsp; "layer" "m" "--" "") <br>(command "ucs" "w" "layer" "lo" "-cons,-snap,-comments,cons,snap,comments,--*" "")<br>(if(setq fil_nam (entsel "select block name from text on screen or hit &lt;return&gt;"))<br>(progn<br>(setq fil_nam (cdr (assoc 1(entget (car fil_nam)))))<br>(command "_block" fil_nam)<br>)<br>;else<br>(command "_block")<br>)<br>)<br><br>avsak bez uspechu.<br>]]>
   <pubDate>Wed, 02 Oct 2013 17:23:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80777&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80777</guid>
   <title><![CDATA[LISP - aktualizacia datumu jednoriadkoveho textu :  M&#367;&#382;ete pou&#382;&#237;t t&#345;eba metodu 2...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80776&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80776</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18008<br /><strong>Zasláno:</strong> 02.říj.2013 v 16:42<br /><br />Můžete použít třeba metodu 2 z tipu:<div><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=6367">http://www.cadforum.cz/cadforum/qaID.asp?tip=6367</a></div>]]>
   <pubDate>Wed, 02 Oct 2013 16:42:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80776&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80776</guid>
   <title><![CDATA[LISP - aktualizacia datumu jednoriadkoveho textu : Dobry den,vie prosim niekto poradit,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80774&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80774</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51727">hazometer</a><br /><strong>Předmět:</strong> 18008<br /><strong>Zasláno:</strong> 02.říj.2013 v 15:14<br /><br />Dobry den,<br><br>vie prosim niekto poradit, resp. napisat LISP na nasledujucu funkciu?<br><br>pri definicii bloku vo vykrese pouzivame ako identifikaciu datumu poslednej zmeny jednoriadkovy text (textovy retazec), kde treba manualne zmenit datum vzdy, ked dojde k redefinovaniu (update) bloku vo vykrese.<br><br>vie prosim niekto napisat kratky LISP, ktory:<br>1. vyzve na vyselektovanie textu, ktory treba aktualizovat aktualnym datumom a casom<br>2. nasledne prepise dany retazec?<br><br>vdaka mockrat<br><br>M<br>]]>
   <pubDate>Wed, 02 Oct 2013 15:14:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18008&amp;PID=80774&amp;title=lisp-aktualizacia-datumu-jednoriadkoveho-textu#80774</guid>
