  <title>CAD F&#243;rum : Export stínu do DWG</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Export stínu do DWG]]></description>
  <pubDate>Tue, 15 Sep 2026 18:05:48 +0000</pubDate>
  <lastBuildDate>Thu, 07 Nov 2013 14:15:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18164</WebWizForums:feedURL>
   <title><![CDATA[Export stínu do DWG : Nane&#353;t&#283;st&#237; nijak. Revit to neum&#237;....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81733&amp;title=export-stinu-do-dwg#81733</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 07.lis.2013 v 14:15<br /><br />Naneštěstí nijak. Revit to neumí. Jedinou možností je export do obrázku.]]>
   <pubDate>Thu, 07 Nov 2013 14:15:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81733&amp;title=export-stinu-do-dwg#81733</guid>
   <title><![CDATA[Export stínu do DWG : v inom pripade neviem poradit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81727&amp;title=export-stinu-do-dwg#81727</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 07.lis.2013 v 13:16<br /><br />v inom pripade neviem poradit ... ako sa vam to nakoniec podarilo ?<br>]]>
   <pubDate>Thu, 07 Nov 2013 13:16:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81727&amp;title=export-stinu-do-dwg#81727</guid>
   <title><![CDATA[Export stínu do DWG : Dobr&#253; den,d&#283;kuji za rady. Obr&#225;zek...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81489&amp;title=export-stinu-do-dwg#81489</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 31.říj.2013 v 17:20<br /><br />Dobrý den,<div><br></div><div>děkuji za rady. Obrázek by byl taky alternativním řešením, ale pak bych jej musel vektorizovat atp., a tomu jsem se chtěl vyhnout.</div>]]>
   <pubDate>Thu, 31 Oct 2013 17:20:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81489&amp;title=export-stinu-do-dwg#81489</guid>
   <title><![CDATA[Export stínu do DWG : Kolega pot&#345;eboval dwg a ne obr&#225;zek...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81488&amp;title=export-stinu-do-dwg#81488</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 31.říj.2013 v 16:27<br /><br />Kolega potřeboval dwg a ne obrázek :-)]]>
   <pubDate>Thu, 31 Oct 2013 16:27:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81488&amp;title=export-stinu-do-dwg#81488</guid>
   <title><![CDATA[Export stínu do DWG : neda sa to cez Aplika&#269;n&#237; menu-Exportovat-Obr&#225;zky...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81462&amp;title=export-stinu-do-dwg#81462</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 31.říj.2013 v 12:25<br /><br />neda sa to cez <em>Aplikační menu-Exportovat-Obrázky a <acr&#111;nym ="term" title="Slovník:  zdánlivý pohyb vytvořený pomocí po sobě rychle za sebou zobrazených snímků">animace</acr&#111;nym>-Obrázek ?<br></em>potom je jeden program na to advance concrete kde sa daju taketo veci dorobit <br>]]>
   <pubDate>Thu, 31 Oct 2013 12:25:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81462&amp;title=export-stinu-do-dwg#81462</guid>
   <title><![CDATA[Export stínu do DWG : Mysl&#237;m, &#382;e to lehce nejde :-(...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81456&amp;title=export-stinu-do-dwg#81456</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 31.říj.2013 v 11:34<br /><br />Myslím, že to lehce nejde :-( Vždyť ani vytisknout stíny vektorově neumí, vždy se tam objeví hláška o převodu do bitmapy.&nbsp;<div>Jedna cesta je export modelu do ifc, import do acadu a zapnout hw stíny v acadu (AA).</div>]]>
   <pubDate>Thu, 31 Oct 2013 11:34:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81456&amp;title=export-stinu-do-dwg#81456</guid>
   <title><![CDATA[Export stínu do DWG : Dobr&#253; den,existuje pros&#237;m n&#283;jak&#253;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81415&amp;title=export-stinu-do-dwg#81415</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=270">PepaR</a><br /><strong>Předmět:</strong> 18164<br /><strong>Zasláno:</strong> 29.říj.2013 v 17:41<br /><br />Dobrý den,<div><br></div><div>existuje prosím nějaký způsob, jak vyexportovat pohled do DWG, včetně stínu, příp. hraniční křiky stínu?</div><div><br></div><div><br></div><div>Předem děkuji za rady</div>]]>
   <pubDate>Tue, 29 Oct 2013 17:41:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18164&amp;PID=81415&amp;title=export-stinu-do-dwg#81415</guid>
