  <title>CAD F&#243;rum : Nastavení Quadro K2000</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAD hardware : Nastavení Quadro K2000]]></description>
  <pubDate>Thu, 30 Apr 2026 04:05:40 +0000</pubDate>
  <lastBuildDate>Thu, 07 Nov 2013 13:10:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18177</WebWizForums:feedURL>
   <title><![CDATA[Nastavení Quadro K2000 : odstranila sa zavada?  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81725&amp;title=nastaveni-quadro-k2000#81725</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18177<br /><strong>Zasláno:</strong> 07.lis.2013 v 13:10<br /><br />odstranila sa zavada?]]>
   <pubDate>Thu, 07 Nov 2013 13:10:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81725&amp;title=nastaveni-quadro-k2000#81725</guid>
   <title><![CDATA[Nastavení Quadro K2000 : Odporucam nainstalovat aktualny...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81537&amp;title=nastaveni-quadro-k2000#81537</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18177<br /><strong>Zasláno:</strong> 04.lis.2013 v 07:52<br /><br />Odporucam nainstalovat aktualny driver na tu VGA a optimalizuju sa automaticky nadstavenia podla komponentov v PC.<br>Ak sa nemylim :)<br>]]>
   <pubDate>Mon, 04 Nov 2013 07:52:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81537&amp;title=nastaveni-quadro-k2000#81537</guid>
   <title><![CDATA[Nastavení Quadro K2000 : Podle mn&#283; je takov&#225; karta pro...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81534&amp;title=nastaveni-quadro-k2000#81534</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=30664">Usak</a><br /><strong>Předmět:</strong> 18177<br /><strong>Zasláno:</strong> 02.lis.2013 v 17:57<br /><br />Podle mně je taková karta pro PowerShape a tím spíš pro PowerMill zbytečná, protože nevyužije její pokročilé funkce za které platíte. Ale když už jí máte, zkuste zvýšit nebo snížit verzi driveru pro Windows.]]>
   <pubDate>Sat, 02 Nov 2013 17:57:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81534&amp;title=nastaveni-quadro-k2000#81534</guid>
   <title><![CDATA[Nastavení Quadro K2000 : Jste si jistej &#382;e to pad&#225; kv&#367;li...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81533&amp;title=nastaveni-quadro-k2000#81533</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=52182">Pflegr</a><br /><strong>Předmět:</strong> 18177<br /><strong>Zasláno:</strong> 02.lis.2013 v 17:47<br /><br />Jste si jistej že to padá kvůli grafice? Není to nějaká skládačka počítač a neperou se tam třeba paměti?]]>
   <pubDate>Sat, 02 Nov 2013 17:47:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81533&amp;title=nastaveni-quadro-k2000#81533</guid>
   <title><![CDATA[Nastavení Quadro K2000 : Dobr&#253; den,m&#225;m nal&#233;hav&#253; probl&#233;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81497&amp;title=nastaveni-quadro-k2000#81497</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=52356">Svajla</a><br /><strong>Předmět:</strong> 18177<br /><strong>Zasláno:</strong> 01.lis.2013 v 07:30<br /><br />Dobrý den,<div>mám naléhavý problém s nastavení grafické karty. Prosil bych o radu. Grafická karta je <b>Nvidia Quadro K2000</b> (&nbsp;<span style="line-height: 1.4;"><a href="http://www.czc.cz/hp-nvidia-quadro-k2000-2gb/131185/produkt" target="_blank" rel="nofollow">http://www.czc.cz/hp-nvidia-quadro-k2000-2gb/131185/produkt</a></span>&nbsp;). V práci používám programy <u>CAD</u> <b>PowerSHAPE 2014</b> a <u>CAM</u> <b>PowerMILL 2014</b>. Moc bych Vás chtěl poprosit o radu jak nejlépe nastavit grafickou kartu, tak aby šlapala jak má. Momentálně mám problémy, že mi programy padají samy od sebe. Dále v PC mám&nbsp;</div><div><b>Procesor:</b> Intel Core i7-3770 CPU 3.40GHz</div><div><b>Paměť (RAM):</b> 16GB DDR3 Kingston Hyper-X</div><div><b>Systém:</b> 64bit Windows 7 Professional</div><div><b>HDD</b> 1000GB + <b>SSD</b> 128GB</div><div><br></div><div>Děkuji za radu a ještě jednou prosím</div><div><br></div><div>S pozdravem Švajda Ladislav CAD/CAM programátor</div>]]>
   <pubDate>Fri, 01 Nov 2013 07:30:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18177&amp;PID=81497&amp;title=nastaveni-quadro-k2000#81497</guid>
