  <title>CAD F&#243;rum : Design Accelerator</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : Design Accelerator]]></description>
  <pubDate>Mon, 02 Nov 2026 04:19:34 +0000</pubDate>
  <lastBuildDate>Fri, 22 Nov 2013 15:08:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18319</WebWizForums:feedURL>
   <title><![CDATA[Design Accelerator : ja vidim roblem v tej aktualizacii...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82106&amp;title=design-accelerator#82106</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 15:08<br /><br />ja vidim roblem v tej aktualizacii asi sa nejako zle prepisali subory, mate tam aj hotfix? ten vlastne opravuje taketo chyby tak skuste to :) ]]>
   <pubDate>Fri, 22 Nov 2013 15:08:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82106&amp;title=design-accelerator#82106</guid>
   <title><![CDATA[Design Accelerator : ne ne vse aktualni. SP2 ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82099&amp;title=design-accelerator#82099</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25745">Fiki</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 11:36<br /><br />ne ne vse aktualni. SP2<br>]]>
   <pubDate>Fri, 22 Nov 2013 11:36:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82099&amp;title=design-accelerator#82099</guid>
   <title><![CDATA[Design Accelerator : a mate tam aj nejaky SP? alebo...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82097&amp;title=design-accelerator#82097</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 11:27<br /><br />a mate tam aj nejaky SP? alebo nerobila sa nejaka aktualizacia?<br>]]>
   <pubDate>Fri, 22 Nov 2013 11:27:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82097&amp;title=design-accelerator#82097</guid>
   <title><![CDATA[Design Accelerator : ne ne asi jsme se nepochopili....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82089&amp;title=design-accelerator#82089</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25745">Fiki</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 08:53<br /><br />ne ne asi jsme se nepochopili. PŘÍKLAD: viz obrazek<img src="uploads/25745/scr01.jpg" height="1050" width="1680" border="0" /><br>]]>
   <pubDate>Fri, 22 Nov 2013 08:53:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82089&amp;title=design-accelerator#82089</guid>
   <title><![CDATA[Design Accelerator : nejedna sa o to ze to mate zavazbene?najprv...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82085&amp;title=design-accelerator#82085</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=51674">waldosinka</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 07:03<br /><br />nejedna sa o to ze to mate zavazbene?<br>najprv by ste mali odstranit nacrt tej diery a potom samotnu dieru<br>]]>
   <pubDate>Fri, 22 Nov 2013 07:03:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82085&amp;title=design-accelerator#82085</guid>
   <title><![CDATA[Design Accelerator : Zdrav&#237;m u&#382;ivatele =) cht&#283;l bych...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82083&amp;title=design-accelerator#82083</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25745">Fiki</a><br /><strong>Předmět:</strong> 18319<br /><strong>Zasláno:</strong> 22.lis.2013 v 07:00<br /><br />Zdravím uživatele =) chtěl bych se zeptat zda by mi někdo poradil jak v aplikaci<acr&#111;nym><font size="2"><font face="Arial, Helvetica"> Design Accelerator odebrat komponenetu kterou prochazí díra. Problém není v odebrání, to řeší klávesa DELETE, ale problém nastane, když toto provedu, tak všechny ostatní šroubové spoje se mi vysvítí že mají problem, ale klasické červené + nic nehlasí. Jak teda můzu ze šroubového spoje vyjmout součást, kterou prochazí díry vytvořene v součásti nad problematickou součástí kterou chci odebrat. Jestli to je nekdo v tipech, tak se omlouvám za založení, ale nějak jsem to nemohl najít. Ještě takovej postřeh používám inventor 2012 a v aplikaci, kde jsou součásti uvedeny v pravo ve sloupečku, kde se mi ukazuje jakou díru to bude delat a kde chci mít závit tak je sdružené tlačítko kde je vyšedlí čevený křížek pro odebrání.</font></font></acr&#111;nym><font ="msgAtxt" face="Arial, Helvetica" size="2"><acr&#111;nym ="term" title="Slovník:  Inventor Design Accelerator - funkční rozšíření Autodesk Inventoru od R10 součástí Inventoru, bývalý Mechsoft pro Inventor"><br></acr&#111;nym></font>]]>
   <pubDate>Fri, 22 Nov 2013 07:00:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18319&amp;PID=82083&amp;title=design-accelerator#82083</guid>
