  <title>CAD F&#243;rum : RPC v Navisworks</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : RPC v Navisworks]]></description>
  <pubDate>Wed, 05 Aug 2026 16:09:50 +0000</pubDate>
  <lastBuildDate>Wed, 29 Jan 2014 11:00:50 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18653</WebWizForums:feedURL>
   <title><![CDATA[RPC v Navisworks :  Dobr&#253; den,mohly by to b&#253;t stromy,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83763&amp;title=rpc-v-navisworks#83763</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25">Hrnčíř</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 29.led.2014 v 11:00<br /><br />Dobrý den,<div>mohly by to být stromy, rostliny, auta, apod (lidi&nbsp;jsou v adresáři Navisworksu).&nbsp;</div>]]>
   <pubDate>Wed, 29 Jan 2014 11:00:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83763&amp;title=rpc-v-navisworks#83763</guid>
   <title><![CDATA[RPC v Navisworks :  Jinak stahovat m&#367;&#382;ete RPC soubory...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83759&amp;title=rpc-v-navisworks#83759</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 29.led.2014 v 09:34<br /><br />Jinak stahovat můžete RPC soubory i rovnou od ArchVision -&nbsp;jen část je ale zdarma. Potřebný Dashboard je k dispozici třeba na Exchange Apps:<div><a href="http://apps.exchange.autodesk.com/ARCH/cs/Detail/Index?id=appstore.exchange.autodesk.com%3aarchvisi&#111;nrpcpluginc&#111;ntent%3aen" target="_blank" rel="nofollow">http://apps.exchange.autodesk.com/ARCH/cs/Detail/Index?id=appstore.exchange.autodesk.com%3aarchvisionrpcplugincontent%3aen</a></div><div>&nbsp;</div><div>Stažené RPC soubory je pak třeba přesunout ze složky C:\RPC do C:\Program Files\Autodesk\Navisworks Manage 2014\presenter\lads\layla_data\textures\RPC\&nbsp;&nbsp; <em>(příklad)</em></div>]]>
   <pubDate>Wed, 29 Jan 2014 09:34:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83759&amp;title=rpc-v-navisworks#83759</guid>
   <title><![CDATA[RPC v Navisworks :  Asi ne, ale popt&#225;m se je&#353;t&#283;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83754&amp;title=rpc-v-navisworks#83754</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 29.led.2014 v 08:18<br /><br />Asi ne, ale poptám se ještě kolegů. Z jaké oblasti by ty RPC měly být? (lidi? rostliny?...)]]>
   <pubDate>Wed, 29 Jan 2014 08:18:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83754&amp;title=rpc-v-navisworks#83754</guid>
   <title><![CDATA[RPC v Navisworks : Dobr&#253; den,CAD Studio nem&#225; ve sv&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83752&amp;title=rpc-v-navisworks#83752</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25">Hrnčíř</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 29.led.2014 v 07:51<br /><br /><p>Dobrý den,</p><div>CAD Studio nemá ve své databázi nějaké RPC soubory, které by se daly stáhnout?</div><div>Děkuji za informaci.</div>]]>
   <pubDate>Wed, 29 Jan 2014 07:51:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83752&amp;title=rpc-v-navisworks#83752</guid>
   <title><![CDATA[RPC v Navisworks :  Zm&#283;nami form&#225;tu RPC. Navisworks...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83736&amp;title=rpc-v-navisworks#83736</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 12:46<br /><br />Změnami formátu RPC. Navisworks nemusí některé knihovny v novějším formátu RPC správně zpracovat, ale nevím jak moc to reálně nastává.]]>
   <pubDate>Tue, 28 Jan 2014 12:46:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83736&amp;title=rpc-v-navisworks#83736</guid>
   <title><![CDATA[RPC v Navisworks :   Vladim&#237;r Michl napsal(a): nov&#283;j&#353;&#237;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83734&amp;title=rpc-v-navisworks#83734</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 12:10<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Původně odeslal(a) Vladimír Michl" alt="Původně odeslal(a) Vladimír Michl" style="vertical-align: text-bottom;" /> <strong>Vladimír Michl napsal(a):</strong><br /><br />novější RPC knihovny nemusejí v Navisworksu pracovat.</td></tr></table><div>To je omezením NW nebo RPC?</div>]]>
   <pubDate>Tue, 28 Jan 2014 12:10:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83734&amp;title=rpc-v-navisworks#83734</guid>
   <title><![CDATA[RPC v Navisworks :  RPC obsah lze vytv&#225;&#345;et v Dashboardu...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83731&amp;title=rpc-v-navisworks#83731</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 10:12<br /><br />RPC obsah lze vytvářet v Dashboardu nebo v RPC Creatoru (oba od Archvision). Viz např. tip:<div><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=4744">http://www.cadforum.cz/cadforum/qaID.asp?tip=4744</a></div>]]>
   <pubDate>Tue, 28 Jan 2014 10:12:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83731&amp;title=rpc-v-navisworks#83731</guid>
   <title><![CDATA[RPC v Navisworks :  Dobr&#253; den,jak&#253; je postup p&#345;i...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83728&amp;title=rpc-v-navisworks#83728</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25">Hrnčíř</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 09:09<br /><br />Dobrý den,<div>jaký je postup při tvorbě vlastního RPC souboru a v jakém softwaru?</div><div>Děkuji za informaci.</div>]]>
   <pubDate>Tue, 28 Jan 2014 09:09:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83728&amp;title=rpc-v-navisworks#83728</guid>
   <title><![CDATA[RPC v Navisworks :  Ofici&#225;ln&#237; RPC knihovny jsou...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83727&amp;title=rpc-v-navisworks#83727</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 08:58<br /><br />Oficiální RPC knihovny jsou placené - <a href="http://www.archvisi&#111;n.com" target="_blank" rel="nofollow">www.archvision.com</a>, ale jde si vytvářet vlastní. Pozor, novější RPC knihovny nemusejí v Navisworksu pracovat.]]>
   <pubDate>Tue, 28 Jan 2014 08:58:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83727&amp;title=rpc-v-navisworks#83727</guid>
   <title><![CDATA[RPC v Navisworks :  Dobr&#253; den,daj&#237; se n&#283;kde st&#225;hnout...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83725&amp;title=rpc-v-navisworks#83725</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=25">Hrnčíř</a><br /><strong>Předmět:</strong> 18653<br /><strong>Zasláno:</strong> 28.led.2014 v 08:15<br /><br />Dobrý den,<div>dají se někde stáhnout RPC soubory pro použití v Navisworku? </div><div>Děkuji za informaci.</div>]]>
   <pubDate>Tue, 28 Jan 2014 08:15:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18653&amp;PID=83725&amp;title=rpc-v-navisworks#83725</guid>
