  <title>CAD F&#243;rum : Prvky z invertoru do revitu</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Prvky z invertoru do revitu]]></description>
  <pubDate>Tue, 22 Sep 2026 03:37:19 +0000</pubDate>
  <lastBuildDate>Sun, 16 Mar 2014 12:48:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=18898</WebWizForums:feedURL>
   <title><![CDATA[Prvky z invertoru do revitu : D&#283;kuji V&#225;m ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84903&amp;title=prvky-z-invertoru-do-revitu#84903</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=37440">marko10</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 16.bře.2014 v 12:48<br /><br />Děkuji Vám]]>
   <pubDate>Sun, 16 Mar 2014 12:48:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84903&amp;title=prvky-z-invertoru-do-revitu#84903</guid>
   <title><![CDATA[Prvky z invertoru do revitu :  Ano, postup v Inventoru LT je...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84900&amp;title=prvky-z-invertoru-do-revitu#84900</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 16.bře.2014 v 11:50<br /><br /><p>Ano, postup v Inventoru LT je úplně stejný. Viz:</p><p><a href="http://help.autodesk.com/view/INVLT/2014/CSY/?guid=GUID-D20CD536-0577-4253-BE0E-F07508BE1E81" target="_blank" rel="nofollow">http://help.autodesk.com/view/INVLT/2014/CSY/?guid=GUID-D20CD536-0577-4253-BE0E-F07508BE1E81</a></p>]]>
   <pubDate>Sun, 16 Mar 2014 11:50:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84900&amp;title=prvky-z-invertoru-do-revitu#84900</guid>
   <title><![CDATA[Prvky z invertoru do revitu : Dobr&#253; den, navazuji na zodpov&#283;zen&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84897&amp;title=prvky-z-invertoru-do-revitu#84897</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=37440">marko10</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 16.bře.2014 v 08:51<br /><br />Dobrý den, navazuji na zodpovězené a prosím o radu zdali jde ten samý import provést do REVITu z INVERTORu LT 2014.  Děkuji]]>
   <pubDate>Sun, 16 Mar 2014 08:51:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84897&amp;title=prvky-z-invertoru-do-revitu#84897</guid>
   <title><![CDATA[Prvky z invertoru do revitu :  L&#233;pe je p&#345;en&#225;&#353;et rovnou .RFA....]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84708&amp;title=prvky-z-invertoru-do-revitu#84708</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 07.bře.2014 v 15:27<br /><br />Lépe je přenášet rovnou .RFA. Natočitelnost závisí na typu rodiny. Problematika rodin je dost široká, doporučoval bych nějaké zaškolení nebo konzultaci.]]>
   <pubDate>Fri, 07 Mar 2014 15:27:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84708&amp;title=prvky-z-invertoru-do-revitu#84708</guid>
   <title><![CDATA[Prvky z invertoru do revitu : D&#283;kuji, to se n&#225;m poda&#345;ilo, ale...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84706&amp;title=prvky-z-invertoru-do-revitu#84706</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=513">Mikemamm</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 07.bře.2014 v 13:20<br /><br />Děkuji, to se nám podařilo, ale vznikl jiný problém. Kolega mi exportoval z inventoru komponentu do *.adsk nicméně je komponenta vkládána do půdorysu v horizontální poloze a potřeboval bych jej ve svislé poloze, nedaří se mi jej otočit ani dát do referenční roviny.... Jak s tímto ?]]>
   <pubDate>Fri, 07 Mar 2014 13:20:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84706&amp;title=prvky-z-invertoru-do-revitu#84706</guid>
   <title><![CDATA[Prvky z invertoru do revitu :  Inventor standardn&#283; podporuje...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84682&amp;title=prvky-z-invertoru-do-revitu#84682</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 06.bře.2014 v 14:00<br /><br />Inventor standardně podporuje export parametrických RFA rodin Revitu - viz:<div><a href="http://www.cadforum.cz/cadforum/podpora-revit-souboru-v-inventoru-tip9208">http://www.cadforum.cz/cadforum/podpora-revit-souboru-v-inventoru-tip9208</a></div>]]>
   <pubDate>Thu, 06 Mar 2014 14:00:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84682&amp;title=prvky-z-invertoru-do-revitu#84682</guid>
   <title><![CDATA[Prvky z invertoru do revitu : Zdrav&#237;m, mohl by n&#283;kdo poradit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84681&amp;title=prvky-z-invertoru-do-revitu#84681</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=513">Mikemamm</a><br /><strong>Předmět:</strong> 18898<br /><strong>Zasláno:</strong> 06.bře.2014 v 13:49<br /><br />Zdravím, mohl by někdo poradit v jakém formátu exportovat z invertoru, abych bloky (např technologie) mohl načíst do revitu ? Ideálně se zachováním parametrických vazeb... Poud toto nelze, tak alespň nějak :)<br />Děkuji]]>
   <pubDate>Thu, 06 Mar 2014 13:49:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=18898&amp;PID=84681&amp;title=prvky-z-invertoru-do-revitu#84681</guid>
