  <title>CAD F&#243;rum : PŘÍKAZOVÝ ŘÁDEK</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : PŘÍKAZOVÝ ŘÁDEK]]></description>
  <pubDate>Tue, 03 Nov 2026 18:30:58 +0000</pubDate>
  <lastBuildDate>Tue, 20 May 2014 11:55:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=19320</WebWizForums:feedURL>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK : D&#283;kuji , to je onoJ.P. ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86199&amp;title=prikazovy-radek#86199</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4973">J.P.</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 11:55<br /><br />Děkuji , to je ono<div>J.P.</div>]]>
   <pubDate>Tue, 20 May 2014 11:55:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86199&amp;title=prikazovy-radek#86199</guid>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK :  T&#345;eba takto: ^C^C(if(not c:fAREA)(load...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86198&amp;title=prikazovy-radek#86198</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 11:17<br /><br />Třeba takto:<div>&nbsp;</div><div><table width="99%"><tr><td><pre class="BBcode">^C^C(if(not c:fAREA)(load "fAREA"))(setq _fAreaSameLayer T);fprop;</pre></td></tr></table></div>]]>
   <pubDate>Tue, 20 May 2014 11:17:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86198&amp;title=prikazovy-radek#86198</guid>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK : Cht&#283;l bych vypsat cel&#253; ten &#345;&#225;dek,...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86197&amp;title=prikazovy-radek#86197</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4973">J.P.</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 09:49<br /><br />Chtěl bych vypsat celý ten řádek, jak by měl vypadat<div>Děkuji&nbsp;</div><div>J.P.</div>]]>
   <pubDate>Tue, 20 May 2014 09:49:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86197&amp;title=prikazovy-radek#86197</guid>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK :  Te&#271; kouk&#225;m, &#382;e tam takov&#253; mechanismus...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86194&amp;title=prikazovy-radek#86194</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 09:00<br /><br />Teď koukám, že tam takový mechanismus už dokonce je. Stačí před spuštěním nastavit proměnnou "_fAreaSameLayer" (třeba v tom menu makru). Přidáno už ve verzi 1.5 (viz Readme). Tedy:<div></div><table width="99%"><tr><td><pre class="BBcode">(setq _fAreaSameLayer T)</pre></td></tr></table>]]>
   <pubDate>Tue, 20 May 2014 09:00:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86194&amp;title=prikazovy-radek#86194</guid>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK :  Chyb&#237; v&#225;m tam &#269;ek&#225;n&#237; na v&#253;b&#283;r...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86193&amp;title=prikazovy-radek#86193</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 08:56<br /><br />Chybí vám tam čekání na výběr pro onen _LAYMCUR:<div>&nbsp;</div><div>_LAYMCUR;<font color="#ff0000">\</font>(if ....</div><div>&nbsp;</div><div>Ale pak stejně budete muset pro FPROP vybrat ten objekt znovu. Jednodušší bude když přidáme volbu "hladina dle objektu" rovnou do fProp (resp. do celé fArea).</div>]]>
   <pubDate>Tue, 20 May 2014 08:56:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86193&amp;title=prikazovy-radek#86193</guid>
   <title><![CDATA[PŘÍKAZOVÝ ŘÁDEK : Dobr&#253; denv palet&#283; n&#225;stroj&#367; m&#225;m...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86192&amp;title=prikazovy-radek#86192</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=4973">J.P.</a><br /><strong>Předmět:</strong> 19320<br /><strong>Zasláno:</strong> 20.kvě.2014 v 08:16<br /><br />Dobrý den<div>v paletě nástrojů &nbsp;mám příkazový řádek:</div><div>&nbsp;^C^C_Laymcur; (if (not c:fAREA) ( load "fAREA"));fprop;</div><div>(představa je taková, že klepnutím na určitou čáru se přepnu do její aktuální hladiny a aplikace fArea k čáře napíše její typ. &nbsp;Potíž je v tom, že příkaz _laymcur mi takto nefunguje, provedese &nbsp;popiska do stávající aktuální hladiny. Kde je chybka?</div><div>Předem děkuji J.P.</div>]]>
   <pubDate>Tue, 20 May 2014 08:16:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19320&amp;PID=86192&amp;title=prikazovy-radek#86192</guid>
