  <title>CAD F&#243;rum : SP3 pro Revit 2015</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : SP3 pro Revit 2015]]></description>
  <pubDate>Tue, 22 Sep 2026 05:16:23 +0000</pubDate>
  <lastBuildDate>Wed, 18 Jun 2014 20:55:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=19486</WebWizForums:feedURL>
   <title><![CDATA[SP3 pro Revit 2015 :  Zde je p&#345;ehled oprav v Revit...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86775&amp;title=sp3-pro-revit-2015#86775</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19486<br /><strong>Zasláno:</strong> 18.čer.2014 v 20:55<br /><br />Zde je přehled oprav v Revit 2015 Update 3, ke stažení viz Download:<div>&nbsp;</div><div><em>* označuje, že problém byl nahlášen uživatelem Revitu</em></div><div>&nbsp;</div><div><strong>Autodesk Revit Architecture 2015 Updates</strong><br>&#61623; Improves performance when placing a large number of adaptive components.<br>&#61623; Updates graphics certification file.<br>&#61623; Improves multi-reference annotation tag grouping when tags contains more than one label.<br>&#61623; Improves preview image retention when families are saved in Project Browser.<br>&#61623; Improves stability of Revit user interface.<br>&#61623; Improves stability when opening Revit project by double-clicking RVT files in Windows Explorer.<br>&#61623; Enables display of project names containing apostrophes in Energy Simulation dialog.<br>&#61623; Improves stability of Energy Simulation when project includes sandwiched Revit elements.*<br>&#61623; Improves stability of rendering in the cloud when the selected view is missing light group data.<br>&#61623; Improves stability of Suite Workflows after double-clicking Workflow Manager.<br>&#61623; Improves rendering results when adaptive components are rendered in the cloud.<br>&#61623; Improves stability when upgrading legacy Revit projects.*<br>&#61623; Improves data integrity when copying or reloading groups that contain shared nested families between projects.<br>&#61623; Improves stability when loading a family while adding a Family Type parameter.<br>&#61623; Improves stability when editing a filter that is owned by another user.<br>&#61623; Improves performance when saving new central file to Revit Server.<br>&#61623; Improves data integrity in projects that contain large elements, such as ImageHolders.*<br>&#61623; Improves stability while opening IFC files.*<br>&#61623; Improves performance when editing masses with applied divided surfaces.<br>&#61623; Improves stability when exporting to SAT format with projects that contain linked files.<br>&#61623; Improves stability during use of the Paste command.<br>&#61623; Improves stability when opening IFC files and modifying Phasing settings.*<br>&#61623; Improves data integrity when swept surfaces are exported to SAT format.*<br>&#61623; Improves stability while exporting to ODBC database when project is missing assembly code settings.<br>&#61623; Improves data integrity in projects created from UK templates.<br>&#61623; Improves stability when canceling out of worksharing permission error while in Design Options.<br>&#61623; Improves stability when closing the Rendering dialog.<br>&#61623; Improves data integrity when closing a local file without synchronizing with central.<br>&#61623; Improves stability when creating material takeoff and then adding parameters.<br>&#61623; Improves stability when exiting Revit.<br>&#61623; Allows proper display of schedules on sheets when fields are sorted or grouped.*<br>&#61623; Allows proper display of selected elements when shadows are enabled in view.<br>&#61623; Improves stability when opening projects that include corrupt families.<br>&#61623; Improves data integrity when copying elements between projects.<br>&#61623; Improves stability when deleting family types from Project Browser.<br>&#61623; Improves stability when working with workshared files.<br>&#61623; Improves results when angular equality constraint is used for doors and windows in curved walls.<br>&#61623; Improves stability when splitting walls.</div><div>&nbsp;</div><div><strong>Autodesk® Revit® 2015 Update Release Notes<br></strong>&#61623; Improves data integrity when default material for a host that is used by families is deleted.<br>&#61623; Improves stability when importing DWG files.<br>&#61623; Improves stability when exiting Revit while Ray Trace visual style is active.<br>&#61623; Improves stability when working with point clouds.<br>&#61623; Improves stability when loading nested families while in Family Editor.<br>&#61623; Improves stability when editing groups.<br>&#61623; Improves regeneration of families that include a reporting parameter.</div><div>&nbsp;</div><div><strong>Autodesk® Revit® MEP 2015 Updates<br></strong>&#61623; Improves calculated airflow results when using a combination of imperial and metric units.<br>&#61623; Improves performance when working with mechanical and piping systems.<br>&#61623; Allows ducts to retain proper alignment after elevation of levels is modified.*<br>&#61623; Improves data integrity when using the Pipe Sizing tool.<br>&#61623; Improves consistency of undo/redo commands while editing a panel schedule template.<br>&#61623; Improves stability when generating pipe layouts.<br>&#61623; Improves data integrity of piping systems when calculation level is set to volume only.<br>&#61623; Allows proper updating of circuit numbers after circuits are moved in panel schedule.<br>&#61623; Allows proper assigning of ASHRAE tables to duct fittings.<br>&#61623; Allows proper display of 3-pole circuits in panel schedules.<br>&#61623; Allows proper retention of circuit loads after assigning a space circuit in a panel schedule.*<br>&#61623; Allows proper retention of circuit assignment after synchronizing with central.*<br>&#61623; Allows taps to remain connected to main duct when taps and ducts reside on different levels and then levels are modified.<br>&#61623; Allows proper updating of electrical fixture parameters when dependent on volts/poles instance parameters.<br>&#61623; Allows duct transitions to remain connected after changing the duct size.*<br>&#61623; Improves stability when dragging cable tray and/or conduit.<br>&#61623; Allows proper connection between circuit and panels to be retained when editing circuit information and panel schedules.<br>&#61623; Improves stability when creating in-place masses while System Browser is open.</div><div>&nbsp;</div><div><strong>Autodesk® Revit® Structure 2015 Updates<br></strong>&#61623; Improves retention of beam annotation settings in projects that were not created from a template.*<br>&#61623; Improves results when mirroring rotated beams and columns.*<br>&#61623; Improves appearance of intersections between concrete beams and walls.*<br>&#61623; Improves stability when editing slanted columns.<br>&#61623; Improves stability when moving shape handles on bar joists while in a section view after disallowing joining.<br>&#61623; Improves stability when using the beam Change Reference tool.<br>&#61623; Improves results when modifying the cross-section rotation of vertical braces.</div><div>&nbsp;</div><div><strong>Autodesk® Revit® API 2015 Updates<br></strong>&#61623; Improves retention of device connections when using Wire.Create to create new wire connecting to a device.<br>&#61623; Improves display of wire connection points when using Wire.ConnectTo and Connector.Connect.<br>&#61623; Enable changes to MEPSystemType.CalculationLevel via public API.<br>&#61623; Level parameter correctly set when elements are placed via NewFamilyInstance().<br>&#61623; Improves retention of parameters in line boundary condition objects.<br>&#61623; Improves stability when using CompoundStructure.SetLayers.*<br>&#61623; Allows proper assignment of a Phase Created value when using DirectShapes.<br>&#61623; Improves alignment of text created via API.<br>&#61623; Improves stability when the API is in Automatic TransactionMode.</div>]]>
   <pubDate>Wed, 18 Jun 2014 20:55:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86775&amp;title=sp3-pro-revit-2015#86775</guid>
   <title><![CDATA[SP3 pro Revit 2015 :  Odkazy na service packy uveden&#233;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86755&amp;title=sp3-pro-revit-2015#86755</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19486<br /><strong>Zasláno:</strong> 17.čer.2014 v 16:18<br /><br /><p>Odkazy na service packy uvedené na naší stránce Download (buď zde na CADfóru nebo na CADstudio.cz) odkazují na oficiální úložiště Autodesku, takže je o plně důvěryhodné instalační soubory. </p><p>Konkrétně včera zveřejněný Update 3 je&nbsp;normální service pack, jen dosud "neprobublal" na veřejné stránky Autodesku ani do Application Manageru, nicméně tam se má objevit během několika hodin či dnů. Je ale docela časté, že service packy zde máme dostupné dříve než jsou&nbsp;zveřejněny na stránkách Autodesku, takže se toho nebojte.</p>]]>
   <pubDate>Tue, 17 Jun 2014 16:18:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86755&amp;title=sp3-pro-revit-2015#86755</guid>
   <title><![CDATA[SP3 pro Revit 2015 : P&#345;e&#269;etl jsem si v News &#382;e u&#382; m&#225;te...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86754&amp;title=sp3-pro-revit-2015#86754</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=129">Jiří Plávek</a><br /><strong>Předmět:</strong> 19486<br /><strong>Zasláno:</strong> 17.čer.2014 v 16:12<br /><br />Přečetl jsem si v News že už máte ke stažení SP3 pro Revit 2015. Na stránce Autodesku ale není tento service pack ještě uveden. Dá se té aktualizaci věřit nebo je to nějaká beta?]]>
   <pubDate>Tue, 17 Jun 2014 16:12:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19486&amp;PID=86754&amp;title=sp3-pro-revit-2015#86754</guid>
