  <title>CAD F&#243;rum : trubka</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Inventor : trubka]]></description>
  <pubDate>Tue, 03 Nov 2026 08:01:13 +0000</pubDate>
  <lastBuildDate>Tue, 26 Aug 2014 06:53:42 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=19796</WebWizForums:feedURL>
   <title><![CDATA[trubka : Ide o klasick&#233; vysunutie.  ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87923&amp;title=trubka#87923</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=44188">cadman181</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 26.srp.2014 v 06:53<br /><br />Ide o klasické vysunutie.<img src="uploads/44188/Vysunutie.JPG" height="828" width="1775" border="0" />]]>
   <pubDate>Tue, 26 Aug 2014 06:53:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87923&amp;title=trubka#87923</guid>
   <title><![CDATA[trubka : nemohl bys mi ud&#283;lat screen???...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87920&amp;title=trubka#87920</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=57873">sobul1989</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 17:12<br /><br />nemohl bys mi udělat screen??? nejde mi to otevřít, mám inventor 2015<br>]]>
   <pubDate>Mon, 25 Aug 2014 17:12:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87920&amp;title=trubka#87920</guid>
   <title><![CDATA[trubka : Tu je model s in&#253;m priemerom.u...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87911&amp;title=trubka#87911</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=44188">cadman181</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 13:31<br /><br />Tu je model s iným priemerom.<a href="uploads/44188/STN_42_6712_-_90_x_500_-_25.ipt" target="_blank" rel="nofollow">uploads/44188/STN_42_6712_-_90_x_500_-_25.ipt</a>]]>
   <pubDate>Mon, 25 Aug 2014 13:31:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87911&amp;title=trubka#87911</guid>
   <title><![CDATA[trubka : m&#367;&#382;e&#353; mi &#345;&#237;ct pros&#237;mt&#283; postup??...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87909&amp;title=trubka#87909</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=57873">sobul1989</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 13:19<br /><br />můžeš mi říct prosímtě postup?? nebo aspoň jestli je ten můj správně jak jsem jej dělal. díky<br>]]>
   <pubDate>Mon, 25 Aug 2014 13:19:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87909&amp;title=trubka#87909</guid>
   <title><![CDATA[trubka :   ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87907&amp;title=trubka#87907</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=10604">maiklss</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 12:48<br /><br /><img src="uploads/10604/asi_tak.JPG" height="677" width="1422" border="0" />]]>
   <pubDate>Mon, 25 Aug 2014 12:48:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87907&amp;title=trubka#87907</guid>
   <title><![CDATA[trubka : uploads/57873/doc1.pdf    ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87905&amp;title=trubka#87905</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=57873">sobul1989</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 11:34<br /><br /><a href="uploads/57873/doc1.pdf" target="_blank" rel="nofollow">uploads/57873/doc1.pdf</a>]]>
   <pubDate>Mon, 25 Aug 2014 11:34:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87905&amp;title=trubka#87905</guid>
   <title><![CDATA[trubka : Ahoj, jak by jste ud&#283;lali podle...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87902&amp;title=trubka#87902</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=57873">sobul1989</a><br /><strong>Předmět:</strong> 19796<br /><strong>Zasláno:</strong> 25.srp.2014 v 11:29<br /><br />Ahoj, jak by jste udělali podle výkresu tuto trubku??? Normálně bych si vymodeloval trubka průměr 88,9, tloušťka 5. <br><br>Pak bych si udělal bod ve vzdálenosti 1172 od kraje.<br>Jd emi o to jestli ta kružnice (poloměr 88) odřízne trubku tak, že průměr 88 bude končit v tom bodě 1172 a nebo jestli v tom bodě 1172 bude střed té kružnice.<br><br><br>děkuji za radu<br>]]>
   <pubDate>Mon, 25 Aug 2014 11:29:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19796&amp;PID=87902&amp;title=trubka#87902</guid>
