  <title>CAD F&#243;rum : Uveden SP4 pro Inventor HSM 2015</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : CAM, 3D tisk a ReCap : Uveden SP4 pro Inventor HSM 2015]]></description>
  <pubDate>Tue, 20 Oct 2026 06:35:38 +0000</pubDate>
  <lastBuildDate>Tue, 30 Sep 2014 12:37:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=19984</WebWizForums:feedURL>
   <title><![CDATA[Uveden SP4 pro Inventor HSM 2015 :  Byl uveden &amp;#034;Update 4&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=19984&amp;PID=88654&amp;title=uveden-sp4-pro-inventor-hsm-2015#88654</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 19984<br /><strong>Zasláno:</strong> 30.zář.2014 v 12:37<br /><br />Byl uveden "Update 4" (SP4) pro CAM aplikaci Inventor HSM 2015 - viz Download. Přehled oprav a rozšíření v SP4:<div>&nbsp;</div><div><span ="Apple-style-span" style="font: 12pxormal arial, sans-serif, helvetica; color: rgb102, 102, 102; text-trans: n&#111;ne; text-indent: 0px; letter-spacing: normal; word-spacing: 0px; white-space: normal; border-collapse: separate; orphans: 2; widows: 2; : rgb247, 252, 254; -webkit-text-size-adjust: auto; -webkit-border-horiz&#111;ntal-spacing: 0px; -webkit-border-vertical-spacing: 0px; -webkit-text-decorati&#111;ns-in-effect: n&#111;ne; -webkit-text-stroke-width: 0px;"><p style="margin: 5px 0px;">1. Surfaces included as Model in Setup are taken into account when calculating toolpaths.</p><p style="margin: 5px 0px;">2. Enabled the selection of multiple bodies and multiple components as Model in Setup.</p><p style="margin: 5px 0px;">3. Added three new stock modes in Setup: “From solid”, “Fixed size cylinder” and “Relative size cylinder”.</p><p style="margin: 5px 0px;">4. Points used to define Tab, Entry positions, etc. can be previewed and moved during creation or edit.</p><p style="margin: 5px 0px;">5. Improved the auto-activation of selection buttons for operations and Height planes, when making a geometry selection in canvas.</p><p style="margin: 5px 0px;">6. Faster parameter expression evaluation and toolpath updates after changes are made.</p><p style="margin: 5px 0px;">7. Improved contour selection behavior to make it easier to select the desired edge loop and contour arrow. This improved selection requires the installation of Inventor 2015 SP1.</p><p style="margin: 5px 0px;">8. Added a “Model” override function in 3D operations such as Parallel, Horizontal, etc.</p><p style="margin: 5px 0px;">9. Added “Avoid/Touch Surfaces” option in 3D operations such as Parallel, Contour, etc.</p><p style="margin: 5px 0px;">10. Bunch of Simulation improvements.</p><p style="margin: 5px 0px;">11. Added a post configuration help file (post.chm) to the Help folder.</p><p style="margin: 5px 0px;">12. Updated the included generic post processor configurations.</p></span></div>]]>
   <pubDate>Tue, 30 Sep 2014 12:37:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=19984&amp;PID=88654&amp;title=uveden-sp4-pro-inventor-hsm-2015#88654</guid>
