  <title>CAD F&#243;rum : Error code is 2738</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Architecture, MEP, Fabrication, Plant 3D : Error code is 2738]]></description>
  <pubDate>Thu, 08 Oct 2026 04:36:10 +0000</pubDate>
  <lastBuildDate>Mon, 19 Oct 2015 15:41:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=21782</WebWizForums:feedURL>
   <title><![CDATA[Error code is 2738 :  Nem&#283;l jstena po&#269;&#237;ta&#269;i antivir...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=21782&amp;PID=95518&amp;title=error-code-is-2738#95518</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 21782<br /><strong>Zasláno:</strong> 19.říj.2015 v 15:41<br /><br />Neměl jste&nbsp;na počítači antivir McAfee nebo Avast? Nástroj McAfee <a href="http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe" target="_blank" rel="nofollow">MCPR</a> nebo <a href="http://www.avast.com/uninstall-utility" target="_blank" rel="nofollow">Avast Uninstall</a> když tak odinstaluje jeho stopy (často způsobující tento problém).]]>
   <pubDate>Mon, 19 Oct 2015 15:41:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=21782&amp;PID=95518&amp;title=error-code-is-2738#95518</guid>
   <title><![CDATA[Error code is 2738 : P&#345;i instalaci AutoCADu Architecture...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=21782&amp;PID=95517&amp;title=error-code-is-2738#95517</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=701">Eger</a><br /><strong>Předmět:</strong> 21782<br /><strong>Zasláno:</strong> 19.říj.2015 v 15:26<br /><br /><span style="font-size: 8.5pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">Při instalaci AutoCADu Architecture 2016 se objevíhláška<span ="apple-c&#111;nverted-space">&nbsp;</span></span><em><span style="font-family:&quot;Verdana&quot;,&quot;sans-serif&quot;">"Theinstaller has encountered an unexpectederror installing this package. This mayindicate a problem with this package. The error code is 2738"</span></em>. Hláškase stejným kódem 2738 mi v poslední době znemožňuje standardníopravu/reinstalaci/odninstalaci&nbsp;AutoCADu Architecture 2013. Pro odstranění problému jsem sepokoušel aplikovat jak postup tento&nbsp;<span style="font-size:  11.0pt;font-family:&quot;Calibri&quot;,&quot;sans-serif&quot;;mso-fareast-font-family:&quot;Times New Roman&quot;;  mso-bidi-font-family:&quot;Times New Roman&quot;;mso-ansi-:CS;mso-fareast-:  EN-US;mso-bidi-:AR-SA"><a href="http://jnp.zive.cz/internal-error-2738-jak-na-problem-s-instalaci" target="_blank" rel="nofollow"><span style="font-size: 8.5pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">http://jnp.zive.cz/internal-error-2738-jak-na-problem-s-instalaci</span></a></span><span style="font-size: 8.5pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">, tak&nbsp;</span><span style="font-size:11.0pt;  font-family:&quot;Calibri&quot;,&quot;sans-serif&quot;;mso-fareast-font-family:&quot;Times New Roman&quot;;  mso-bidi-font-family:&quot;Times New Roman&quot;;mso-ansi-:CS;mso-fareast-:  EN-US;mso-bidi-:AR-SA"><a href="http://helpdesk.cadstudio.cz/helpdesk.html?id=DSK00435" target="_blank"><span style="font-size: 8.5pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">VIP odpověď na tip&nbsp;<strong><span style="font-family:  &quot;Verdana&quot;,&quot;sans-serif&quot;">8299</span></strong>&nbsp;na Helpdesk serveru&nbsp;</span></a></span><span style="font-size: 8.5pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">, bohužel bezvýsledně.&nbsp;</span>Prosím o radu co s tím.]]>
   <pubDate>Mon, 19 Oct 2015 15:26:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=21782&amp;PID=95517&amp;title=error-code-is-2738#95517</guid>
