  <title>CAD F&#243;rum : Around Room</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Around Room]]></description>
  <pubDate>Thu, 24 Sep 2026 06:25:24 +0000</pubDate>
  <lastBuildDate>Wed, 18 Nov 2015 14:24:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=21891</WebWizForums:feedURL>
   <title><![CDATA[Around Room : D&#237;ky ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95897&amp;title=around-room#95897</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 21891<br /><strong>Zasláno:</strong> 18.lis.2015 v 14:24<br /><br />Díky]]>
   <pubDate>Wed, 18 Nov 2015 14:24:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95897&amp;title=around-room#95897</guid>
   <title><![CDATA[Around Room :  V API Revitu nen&#237;, to bude asi...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95895&amp;title=around-room#95895</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 21891<br /><strong>Zasláno:</strong> 18.lis.2015 v 13:13<br /><br />V API Revitu není, to bude asi až&nbsp;z rozhraní na Navisworks.]]>
   <pubDate>Wed, 18 Nov 2015 13:13:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95895&amp;title=around-room#95895</guid>
   <title><![CDATA[Around Room : Zdrav&#237;m, dotaz sp&#237;&#353;e na program&#225;tory:Navisworks...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95864&amp;title=around-room#95864</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=74">Peter Jirat</a><br /><strong>Předmět:</strong> 21891<br /><strong>Zasláno:</strong> 16.lis.2015 v 16:27<br /><br />Zdravím, dotaz spíše na programátory:<div>Navisworks při zobrazení modelu z Revitu jako jednu z vlastností stěny vypisuje parametr Around Room, což je název a číslo místnosti, která je ohraničená právě touto zdí. Dá se na tento parametr nějak šáhnout v Revitu v API? Nebo vzniká při exportu geometrie přes exporter do Navisu?</div>]]>
   <pubDate>Mon, 16 Nov 2015 16:27:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=21891&amp;PID=95864&amp;title=around-room#95864</guid>
