  <title>CAD F&#243;rum : Dotaz na SHX písma</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : AutoCAD : Dotaz na SHX písma]]></description>
  <pubDate>Tue, 20 Oct 2026 19:21:04 +0000</pubDate>
  <lastBuildDate>Mon, 27 Feb 2006 12:38:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=2211</WebWizForums:feedURL>
   <title><![CDATA[Dotaz na SHX písma : D&#283;kuji, pomohlo to OndrejD ]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9364&amp;title=dotaz-na-shx-pisma#9364</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=127">Ondrejd</a><br /><strong>Předmět:</strong> 2211<br /><strong>Zasláno:</strong> 27.úno.2006 v 12:38<br /><br /><P>Děkuji,</P><P>pomohlo to</P><P>OndrejD</P>]]>
   <pubDate>Mon, 27 Feb 2006 12:38:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9364&amp;title=dotaz-na-shx-pisma#9364</guid>
   <title><![CDATA[Dotaz na SHX písma : nemus&#237; to souviset s DWF - zku...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9322&amp;title=dotaz-na-shx-pisma#9322</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 2211<br /><strong>Zasláno:</strong> 24.úno.2006 v 16:23<br /><br />nemusí to souviset s DWF - zkuste:<BR><A href="http://www.cadforum.cz/cadforum/qaID.asp?tip=1005" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=1005</A>]]>
   <pubDate>Fri, 24 Feb 2006 16:23:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9322&amp;title=dotaz-na-shx-pisma#9322</guid>
   <title><![CDATA[Dotaz na SHX písma : Dobr&#253; den, u&#382; od AutoCADu 14...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9321&amp;title=dotaz-na-shx-pisma#9321</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=127">Ondrejd</a><br /><strong>Předmět:</strong> 2211<br /><strong>Zasláno:</strong> 24.úno.2006 v 15:42<br /><br /><P>Dobrý den,</P><P>už od AutoCADu 14 používám jeden definovaný typ písma SHX, s tím že si ho vždy zkompiluju pro příslušnou verzi AutoCADu.</P><P>Při tisku a vykreslování do DWF se mi u písma výšky 2.4 a písmen M a W vykreslují nechtěně dlouhé špičky a těchto písmen. Při vykreslení ve výšce 35 se již neobjevují. </P><P>Nevíte co s tím? Poslal bych DWF náhled, ale nevím jak.</P><P>Děkuji</P><P>OndrejD</P>]]>
   <pubDate>Fri, 24 Feb 2006 15:42:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=2211&amp;PID=9321&amp;title=dotaz-na-shx-pisma#9321</guid>
