  <title>CAD F&#243;rum : Update 4 pro Revit 2016 R2</title>
  <description><![CDATA[Toto je XML obsahový kanál serveru; CAD F&#243;rum : Revit, BIM : Update 4 pro Revit 2016 R2]]></description>
  <pubDate>Sat, 13 Jun 2026 02:55:09 +0000</pubDate>
  <lastBuildDate>Thu, 07 Apr 2016 18:29:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum/RSS_post_feed.asp?TID=22556</WebWizForums:feedURL>
   <title><![CDATA[Update 4 pro Revit 2016 R2 :  Byl uveden Update 4 pro Autodesk...]]></title>
   <link>https://www.cadforum.cz/forum/forum_posts.asp?TID=22556&amp;PID=98281&amp;title=update-4-pro-revit-2016-r2#98281</link>
    <![CDATA[<strong>Autor:</strong> <a href="https://www.cadforum.cz/forum/member_profile.asp?PF=9">Vladimír Michl</a><br /><strong>Předmět:</strong> 22556<br /><strong>Zasláno:</strong> 07.dub.2016 v 18:29<br /><br />Byl uveden Update 4 pro Autodesk Revit 2016 R2 a Revit LT 2016 R2. Ke stažení v sekci Download nebo přes Desktop App. Přehled oprav v UR4:<div>&nbsp;</div><ul id="expList"><li ="collapsed expanded"><strong>Update 4 for Release 2</strong><ul style="display: block;">                 <li ="collapsed expanded"><strong>Platform</strong><ul style="display: block;">                         <li ="collapsed expanded"><i>Assembly</i><ul style="display: block;">                                 <li><span>Corrects an issue where an adaptive component in an assembly would not type match properly and instead would cause a new assembly type to be created.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Color Fill</i><ul style="display: block;">                                 <li><span>Corrects an issue which causes a color fill schema from being applied when using undo and redo commands.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Groups</i><ul style="display: block;">                                 <li><span>Corrects an issue where face-hosted families in a group did not rotate correctly when the group was rotated by 90 degrees.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Linked RVT</i><ul style="display: block;">                                 <li><span>Improves stability when reloading a linked RVT file.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Worksharing</i><ul style="display: block;">                                 <li><span>Corrects a failure during simultaneous Synchronize with Central requests when the model is hosted within Revit Server.* </span>                                 <li><span>Corrects an issue which prevented existing models within Revit Server from being replaced.* </span></li></ul></li></ul></li></ul></li></ul><div><ul style="display: n&#111;ne;">                 <li ="collapsed expanded"><strong>Platform</strong><ul style="display: block;">                         <li ="collapsed expanded"><i>Assembly</i><ul style="display: block;">                                 <li><span>Corrects an issue where an adaptive component in an assembly would not type match properly and instead would cause a new assembly type to be created.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Color Fill</i><ul style="display: block;">                                 <li><span>Corrects an issue which causes a color fill schema from being applied when using undo and redo commands.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Groups</i><ul style="display: block;">                                 <li><span>Corrects an issue where face-hosted families in a group did not rotate correctly when the group was rotated by 90 degrees.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Linked RVT</i><ul style="display: block;">                                 <li><span>Improves stability when reloading a linked RVT file.*</span>                                 </li></ul></li><li ="collapsed expanded"><i>Worksharing</i><ul style="display: block;">                                 <li><span>Corrects a failure during simultaneous Synchronize with Central requests when the model is hosted within Revit Server.* </span>                                 <li><span>Corrects an issue which prevented existing models within Revit Server from being replaced.* </span></li></ul></li></ul></li></ul></div>]]>
   <pubDate>Thu, 07 Apr 2016 18:29:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum/forum_posts.asp?TID=22556&amp;PID=98281&amp;title=update-4-pro-revit-2016-r2#98281</guid>
